  • Instagram
Related Reviews
Yamaha WR450F 2015
Last review by Ken S
Yamaha WR450F 2013
Last review by albertlui
Yamaha WR450F 2008
Last review by Zippo638
Yamaha WR450F 2003
Last review by Dave in Illinois
Yamaha WR450F 2011
Last review by jtklein
Related Garage
Yamaha WR450F (2006)
Owner: Super-Telecom
Added on November 29, 2016
* * * * * 7 votes
What did you do to your WR today?
Yamaha WR400F Yamaha WR450F
4429 replies to this topic
  • Fattony
Posted July 12, 2015 - 05:30 AM
ImageUploadedByThumper Talk1436707744.353619.jpg ImageUploadedByThumper Talk1436707778.674152.jpg
  • Fattony
Posted July 12, 2015 - 05:33 AM
Force radiator guards and ACD bash plate.
  • NewfieThumper
Posted July 13, 2015 - 04:55 PM
Installed a 08 yz450f stock shorty exhaust....noticeable power difference.
  • RMK800
Posted July 13, 2015 - 05:58 PM
What did you install it on, year? I'm interested in this also.
  • NewfieThumper
Posted July 14, 2015 - 06:28 AM
Here is a pic. It's on a 2014 wr450f.
  • Mcflyz450f
Posted July 16, 2015 - 01:09 PM
Today was the First oil change on my 15 WR450f
  • still2smokin
Posted July 16, 2015 - 05:09 PM
I pulled it out to wash it  and put my new registration sticker on ........
but then I opened a beer ......so that didn't happen .
But I did ride it this last weekend for the first time in longer than I would like to admit .
Runs perfect  , the suspension is a bit stiff in the slow stuff but damn near perfect in small jumps and the fast stuff .
Will find a compromise between the two .
I ate shit once but it was nothing .
My Seat Concepts foam and cover should arrive any day :banana: .
Edited by still2smokin, July 16, 2015 - 05:15 PM.
  • KOCONUT
Posted July 18, 2015 - 01:15 PM
just finished the Tusk enduro lighting kit and Trail tech Vapor install.  Still considering if I should invest in a set of Sumo wheels/tires.  Just waiting on the plates now!!!
Edited by KOCONUT, July 18, 2015 - 01:16 PM.
  • Scoutman76
Posted July 20, 2015 - 08:05 AM
Anything to look out for?   I will be working on the same thing this weekend,  along with an X2 headlight and a 100W stator
  • KOCONUT
Posted July 20, 2015 - 09:32 AM
No its pretty straightforward. The hand guards can be a little tight with the controls but it all works great.
  • Scoutman76
Posted July 27, 2015 - 09:05 AM
   The kit was easy to install,  save for wiring in the headlights (I am using a TT X2 with upgraded stator) and eliminating the additional On/Off switch supplied with the kit.    After a bit of research,  I wound up running the battery leads from the Tusk harness differently to use the OEM push button switch.   Simply run the black lead to the NEG battery terminal and tie the red lead to the two brown wires located in the factory plug at the fuse panel next to the battery.   Then,  you can connect the two red wires that were supposed to go to the Tusk switch to complete the circuit.   Now everything will turn on with the factory push button.
   The multi-switch supplied with the kit lacks a diode that would allow it to turn both lights of the X2 on at the same time.   After contacting Trail Tech,  they do not offer a switch with the horn and signals integrated so I had to find a work around.  I wound up using a hot lead from the factory switch directly to one of the two lights on the X2 (low beam) and a second hot lead to the black wire Tusk Multi Switch.   I then connected the tusk high beam lead (blue wire) to the high beam on the X2,  so now my low beam is always on whenever the bike is powered up,  and I can switch the high beam on and off with the Tusk kit.
Note,  this was on a 2004 WR450F,  so other years may or may not be similar
Edited by Scoutman76, July 27, 2015 - 09:06 AM.
  • Scoutman76
Posted July 29, 2015 - 03:10 PM
Finally managed to get my project completed.....  Picked up a bone stock 2004 WR450F a few weeks ago and tore the bike all the way down to the frame.   Went through the motor and replaced anything that wasn't in spec (not much actually),  did all of the normal mods/jetting, replaced every bearing in the chassis and wheels,  added the correct springs and had both ends revalved, installed a modified Tusk DS kit,  TT 100W Stator,  TT X2 light,  TT Vapor, Acerbis 3.3 gal tank,  rebuilt the calipers and master cylinders,  and finished it off with some white plastics and new shroud graphics.....Now just have to go dial the suspension in and make any jetting tweaks and she should be good to go....
  • W R, still2smokin and SmackIt like this
  • Like This
  • Ano25
Posted August 01, 2015 - 03:46 AM
Put on hand guards and some risers ImageUploadedByThumper Talk1438429589.789016.jpg
  • still2smokin
Posted August 01, 2015 - 09:41 AM
Installed my new seat . Looks a little funky but a lot more comfy .
From my ride last weekend ...95 degrees is to be riding but my cooling fan did its job .
  • Bubbles dog
Posted August 01, 2015 - 12:36 PM
ImageUploadedByThumper Talk1438460863.902751.jpg just got my 1999 ca plated wr400f on the road been sitting for 8 years.Traded it for a cj5,ccs racing suspension,baja kit upgraded with LEDs,jd jet kit,Scott fuel screw,14,50 sprockets and chain,aluminum radiators,unibiker rad guard,kenda Parker DT tires,yz plastic.I put more into it than it's worth but it's mine and its street legal.
  • Like This
  • jbtroxler
Posted August 01, 2015 - 04:33 PM
Rode the pi** out of my WR today. Hot and dusty, but it has been 6 weeks since I have really been able to stretch its legs. Good Day!
  • KOCONUT
Posted August 01, 2015 - 05:06 PM
Went for a good 30mile ride today. New tires work great on road, still looking for some gravel roads or trails around here to have fun with. I think a new sprocket set will be on order soon to help me get up over 65mph. Noticed my sealed oil drain bolt has started to leak, guess its time to put in a timesert.
  • spankme144
Posted August 09, 2015 - 04:56 PM
Installed a couple opt7 led pods. Love the extra light output. Pic doesnt do it justice.
23C83433-985E-4359-9B2C-3D0C67C163EB_zps
4E0FE1BA-03B7-4BB9-A258-865F66EEC5BE_zps
F9C78B08-E170-4163-A662-E955102D3739_zps
Thats pretty neat..
  • Bubbles dog
Posted August 10, 2015 - 06:12 AM
Looks good,stater upgrade?
  • 123devinzz1
Posted August 10, 2015 - 03:18 PM
nope. They dont seem to draw much. I just wired them to the battery. Heres a pic i took with my new phone (xperia z3) that takes better pics in the dark. 185F8477-45DC-405F-8567-9530ACEA80F4_zps
Yamaha WR450F 2017 by Chris.GVS
Yamaha WR450F 2017
  • 0 reviews
2012 wr450 headlight by donkeyballz
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  27 replies
Show Us You 2016 WR450f & Mods - last post by Super_Davee
  • 0 replies
Kickstarter Noise by JohnClaude
  • 7 replies
Valve Cover gasket keeps blowing by pbcrazy9898
  • Hot  29 replies
