  • Instagram
Related Garage
Yamaha WR450F (2009)
Owner: AceDub13
Added on November 11, 2016
Related Reviews
Yamaha WR450F 2015
Last review by Ken S
Yamaha WR450F 2006
Last review by Toad Atsma
Yamaha WR450F 2003
Last review by ScubaruSteve
Yamaha WR450F 2011
Last review by jtklein
Yamaha WR450F 2013
Last review by 20 A
* * * * * 7 votes
What did you do to your WR today?
Yamaha WR400F Yamaha WR450F
4445 replies to this topic
  • toten
Posted February 14, 2015 - 05:09 PM
Put a new set of tires on. Decided to go with Bridgestone S20 EVOs, 120/70-17 and 150/60-17. I need to pick up a set of tires for the dirt wheels too, they still have factory tires on them with very minimal use and I don't trust 13 year old tires.
1926705_10101757394638915_36898060155331
  • toten
Posted February 16, 2015 - 04:39 PM
And now a YZ tail, or at least I think that's what it is (the previous owner included it with the bike). Put a DRC Edge taillight on, need to figure out what to do for turn signals.
10982045_10101760561138225_4261687300034
  • RMK800
Posted February 16, 2015 - 08:41 PM
My bike is a 2007 WR450F with about 25 hours on it. I'm doing a bazillion mods, but performance wise:
Grey Wire
AIS Removed
Air Box Mod (just snorkels so far)
Throttle Stop Screw replaced
Exhaust mod via GYTR Replacement End Cap
I'm still digging through twenty thousands posts to figure out the jetting. I ride in the Sierras at 5000-8500 feet altitude. My rough guestimate at this point is:
Main jet: 168
Pilot Jet: 45
PAJ: 110
Leak Jet: 50
Starter Jet: 68
Fuel screw (turns out): stock 1.5
Needle Model/Clip position: No F'in clue
I'm very open to good advise on jetting from those that ride at the same altitude with the the same mods.
Cheers!
I ride between 4500 and 9000 on my 2007. Your MJ is way to high. Mine is a 160MJ and it's perfect. The rest of your setting are the same. I have an after market exhaust.
I did change my needle to the NCVS (YZ needle) 3rd clip down. 4th didn't pull as well. Definitely better then stock and a cheap mod. Buy at boats.net for 12.00.
Also people recommend this http://crfsonly.com/...ate-crf450r.php
I haven't done this yet, but I plan on it. I have only replaced the faulty accelerator pump spring.
Edited by RMK800, February 16, 2015 - 08:45 PM.
  • AtomicGeo
Posted February 19, 2015 - 06:35 PM
Just installed my promoto billet rack...sweet.  :thumbsup:
  • AtomicGeo
Posted February 19, 2015 - 06:38 PM
Just ordered some full coverage backgrounds for my side panels and air box....it's gonna look sick.  :goofy:
  • SurfaceToAir
Posted February 19, 2015 - 06:39 PM
Bike looks good!
For blinkers- I am running tear drop style LED blinkers in the rear, tucked up near the seat, and into where the side panels have the cut out. Keeps them safe and they look like they are stock.
I am not doing SM on my bike- lots of dirt still, and my license plate is in the same place yours is- and its bent to crap  from dumping the bike.
cheers-
Dustin
  • SmackIt
Posted February 22, 2015 - 11:20 AM
Thanks for your input RMK800, one further question.
I'm trying to finish up the carb work and spent the better part of 4 hours digging through the forum.  Things get mixed up between model years, I recommend checking the carb to verify what jets actually came stock.
2007 WR450F (Riding Elevation 5000~9000 Feet / AVG Temp 55~85ºF / AVG Humidity ~45%)
Completed Mods:
Grey Wire
AIS Removed
Air Box Mod
Accelerator Pump Mod
TPS is connected, but I would like to make a switch to turn it on and off.  ON for trail and single track / OFF for longer highways stretches.
I decided on the following for a starting point:
Main Jet: Stock is #168 / Change to #160 (4MX-14943-39-00)
Pilot Jet: Stock is #45 / Keep Stock #45 (4MX-14948-05-00)
Leak Jet: Stock is #60 / Change to #50 (4JT-1494F-07-00)
Starter Jet: Stock is #65 / Change to #68 (3TJ-1494F-14-00)
Needle Model/Clip position: Stock is NFNT / Change to NCVS 3rd clip down. (5TA-14916-VS-00)
Pilot Air Jet: Stock is #70 / Change to #110 ?  I can't find this PAJ from the usual online sources.  I also found comments on the forum stating the PAJ should stay stock (#70) if your ACV remains active.  Perusing the Jetting database, there seems to be a pretty even split between people staying stock and people changing to #100/110.  Where can I get a 110 PAJ and exactly what does it do?
Input and comments appreciated.
  • Juman5
Posted February 22, 2015 - 03:46 PM
Added an FMF Powercore 4 yesterday.  Seems to run much cooler than before.  I had no idea that the stock exhaust was so congested.
  • Derwud
Posted February 22, 2015 - 06:43 PM
Fixed a poor connection on the dual sport kit on the 450 and doing D/S kit to my new to me 250...
  • RMK800
Posted February 23, 2015 - 06:53 PM
Completed Mods:
Grey Wire
AIS Removed
Air Box Mod
Hmm I can't really comment on pilot air jet or starter jet. I never changed those.
The rest of your changes look good. I would also consider an after market fuel screw, make sure it's a brass one, don't put in a cheap aluminum.
I also did the stiffer accelerator pump spring instead of doing the O-ring mod.
You can try to get in touch with a member that helped me Krannie or kur ran ne... Something like that. He is very good and can help you with anything on the carb.
Edited by RMK800, February 23, 2015 - 06:56 PM.
  • still2smokin
Posted March 01, 2015 - 06:57 PM
Started installing my new Acerbis 3.3g tank and it looks like it will surely stop my gas boiling problem
as there is lots more room around the engine .
The IMS 3.1g tank carries its fuel lower and closer to the engine .
not thrilled with the new graphics.......might just order a set of the graphics I had before .
Edited by still2smokin, March 01, 2015 - 06:58 PM.
  • W R
Posted March 02, 2015 - 06:36 AM
Dont over think it. There is nothing wrong with the new graphics. Just not what you are used to looking at.
  • 5270ADVRIDER
Posted March 03, 2015 - 04:02 PM
Rode on the ice for the first time this weekend. Too much fun!
  • BlueBeast400
Posted March 06, 2015 - 06:30 PM
Went to the garage to tinker with bike a little. Things got a little out of hand...
  • toten
Posted March 07, 2015 - 01:34 PM
If you're interested in selling your old tank let me know, I could use a bigger tank for my bike and I'm local.
  • MarkandtheBRP
Posted March 07, 2015 - 07:05 PM
Took my "new" 03 450 out on the trail today for the first time. Ran pretty well. Still trying to dial in the jetting, a little stutter down low. Happy with it overall.
  • SmackIt
Posted March 07, 2015 - 07:21 PM
Spent a couple hours sorting things out around the handlebars.  I'm using the Tusk hand guards with integrated turn signals and the other wiring to make her road legal.  Gatos Bros sent me some beautiful hand guard mounts and they work great.  I've got a thread going over here and will update it soon.
I had to modify the brake line guide, but everything else fit perfectly.
The Gatos Bros mounts save a lot of room on the handle bars.
Slowly getting there.  I finally got my Clarke tank, Seat Concepts seat, and Pro Moto rack mounted.
Traveling for work until April, so I won't be able to finish up till then.
Cheers!
  • still2smokin
Posted March 07, 2015 - 10:32 PM
Not interested in selling or even giving to anybody .
That tank is a disaster waiting to happen which is why I replaced it .
It touches the cylinder head/ valve cover on both sides of the engine ,
eventually causing the gas to boil and pressurize the tank and then it bogs out most inconveniently
until you open the gas cap and let the bike/gas in the tank cool down enough to stop the boiling fuel .
Seriously , you don't want this IMS 3.1g tank and I would not feel right about passing on
a known time bomb .
IF you want a bigger tank buy the Acerbis 3.3g .
  • toten
Posted March 08, 2015 - 10:16 AM
It actually touches the head? Wow, that is pretty bad.
I was figuring that since my bike is a supermoto I'd typically have more airflow and therefore lower fuel temps so it was less likely to be a problem, but I don't know how bad it is.
  • MarkandtheBRP
Posted March 25, 2015 - 12:22 PM
A Motoz Mountain Hybrid for my 450... And a Tusk rim. Tubliss on its way. Can't wait!
Should i switch to a ktm 300 exc or xcw from a 2009 wr 450f by Tattoojunk
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  76 replies
05 wr450 oil leaking from fuel tank mounting hole by gee-tee
  • 0 replies
Show Us You 2016 WR450f & Mods by chelder
  • Hot  34 replies
any reason why to get new Beta 450rr instead of wr450f ? by motf
Dirt Bike   Make / Model Specific   Beta
  • Hot  80 replies
  • 0 replies
