  • Instagram
Related Garage
Yamaha WR450F (2006)
Owner: Toad Atsma
Added on December 25, 2016
Related Reviews
Yamaha WR450F 2005
Last review by Kalamazoo
Yamaha WR400F 2000
Last review by twerth
Yamaha WR450F 2011
Last review by jtklein
Yamaha WR450F 2009
Last review by msowsun
Yamaha WR450F 2007
Last review by cbsander
* * * * * 7 votes
What did you do to your WR today?
Yamaha WR400F Yamaha WR450F
4436 replies to this topic
  • Jeromba
Posted August 17, 2014 - 07:38 PM
My 2008 WR450 setup for the Great Divide Trail. We ran this 2,500 mile route from Canada to Mexico this summer and the WR and my adventure setup did great. I did have an issue with the rear rack, but luckily it was at the end of the trail and the issue is repairable.
Happy to answer questions and/or share details of my setup.
  • jetfuel, revelc and Andrew Watson like this
  • Like This
  • Ron W
Posted August 17, 2014 - 07:50 PM
Installed a Rekluse Z-Pro Start auto-clutch on my 2005 WR450F.
Took it out for the required break-in, gap check and a little play riding.
Rekluse doesn't make the EXP 3.0 (their newest version) for my 05 WR, so I went with the Z-Pro Start.
What a hoot! I never realized how much I used the clutch while riding. Now I have to develope a whole new set of reflexes, because I don't need to hold the clutch the way I used to.
It's really cool when you come into a wash with loose rocks. You just slow down, focus on where you want to go and pick your way through.
I understand its a bad habit to get into because it is supposedly a lot harder on the clutch, but its amazing how you can just leave it in 3rd gear in the rough stuff and just motor through.
With a standard clutch the engine would be lugging and a down shift would be needed. But because the clutch is sensitive to engine speed not wheel speed, it can slip and not lug the motor.
You just about have to ride it to understand what I'm trying to say.
I know they are a little pricey, but from my research they appear to be very well built and last a long time.
If your on the fence about buying one, I would highly recommend it.
Edited by Ron W, August 17, 2014 - 07:52 PM.
  • still2smokin and revyrider like this
  • Like This
  • Andrew Watson
Posted August 18, 2014 - 02:52 AM
Jeromba,
Can you tell us what did for the rear end of the bike to take the additional weight in photo. I'm trying to adventurise my 2012 WR at the moment and I'm trying to figure out what to do for a rack for luggage etc.
Andrew
  • Jeromba
Posted August 18, 2014 - 08:44 AM
The weight I needed to carry consisted of ~25 lbs of camping gear and tools plus 2 gallons of gasoline (only 1 gallon per rotopak). The total weight on the rack was ~37 lbs. When searching for a rack, I wanted a rack that was not fully reliant on the subframe to support the weight. There are not many racks available for the WR450. The Cycleracks.com rack was the only one I found with legs that extend the weight to the frame, rather then rely on the subframe. You can see a better picture of the rack here https://cycleracks.c...26/Default.aspx
After I purchased the rack, I fabricated aluminum mounting plates on either side for the rotopaks. I should have also added some triangulation from the aluminum plates to the lower legs of the rack.
My rack performed well for 2000 miles, but failed due to excessive flexing at a critical point. I don't know how to upload a picture to this reply, so I'll need to explain: Take a look at the picture of my rack in the original post. At the upper left hand corner of the rotopak you'll see the rack has a prominent bend in the leg that later connects to the frame. This prominent bend was the point of failure. An easy way to fix this weak point is to fabricate and weld a truss section underneath the lower leg. In the case of my specific setup, I simply need to add a support that extends from the aluminum plate to the lower leg.
  • Sidewinder1970
Posted August 21, 2014 - 02:45 AM
Installed a lithium ion batt. Weight: just more than 500 gram.
  • Derwud
Posted August 21, 2014 - 05:12 AM
Just did the same. The weight difference is unbelievable... So far no problems..
  • LucasLeader
Posted August 21, 2014 - 02:14 PM
I had one in my DR650 for a couple of years and the only problem I had was when it was below about 40F. I had to get some current going through it before it would turn the engine over.
  • MidlifeCrisisGuy
Posted August 21, 2014 - 07:12 PM
I washed it, thoroughly !
It was very dirty from a lot of riding the last couple months.
Presently sporting a flat back tire.  It spun on the rim when the bike landed after being airborn while climbing a hill full throttle in 2nd gear.  Pretty aggressive on my part.   I had it aired down (6 PSI ?, too far) because it was slippery as snot on the weekend.
Spent a great afternoon on Sunday doing nothing but trying to climb big long hills in terrible, slippery conditions.  What a blast.  I was terribly sore and tired on Monday though.  Funny story... I was cursing my skills and the bike after spinning out half way up one hill.   Only to find it was so slick I couldn't stand !   I guess I did pretty well going as high as I did.   The guys on the XR600 and the YZ250F wouldn't even try !  LOL.
  • MANIAC998, revyrider and revelc like this
  • Like This
  • RMK800
Posted August 22, 2014 - 01:20 PM
I just purchased a Shorie Lithium battery. Getting it today. It seems you cannot charge it by a regular charger? What if you put it on a two amp battery tender? Did you buy any special charger?
  • vlxjim
Posted August 22, 2014 - 01:35 PM
You don't need the special charger. The port is for a balance charger but the battery has an internal passive balancing circuit. So yes the battery tender will work fine. You just cannot use a sophisticated charger that has desulfation mode on it.
  • revelc
Posted August 22, 2014 - 02:30 PM
Rode my bike 20 miles to work. Installed hand guards and started pricing parts for a dual sport conversion.
I think I can pull it off for less than $100.
Also added the OZ map with my brand new tuner. It makes wheelies much more fun and controllable :)
2014 WRR R.I.Pieces
2012 WR450F ECU, GYTR tuner, Yoshi RS4, MSR rad guards, Cycra Pros, and a growing wish list...
  • aust014
Posted August 23, 2014 - 09:55 PM
Last weekend I put a 2013 headlight on my 05 WR450, oh and installed a fan.
  • MountainRider35
Posted August 24, 2014 - 12:20 AM
Not all today but in two weeks I bought a 05 wr450 put on new tires, installed a keyed ignition, new air filter, changed from oversized tank to stock, installed jd jet kit and cleaned the carb wow never seen one so bad!, new petcock, also new crank case cover gasket and bolt.
  • DRZ04
Posted August 24, 2014 - 08:19 PM
Aust what radiator guards do you have on and where did you get the fan? Did you have to adapt from another or what? I would like to put one on my '12.
  • aust014
Posted August 25, 2014 - 10:48 AM
I got the fan off of ebay, here's the link to that fan http://www.ebay.com/...=STRK:MEBIDX:IT if you get the fan and wire it up and it is a pusher not a puller that is because the wires need to be switched around (know from experience). The switch I used to turn it on and off is  http://www.ebay.com/itm/141140656787?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT. The radiator guards I believe say Devol on them, I will check to see if I am right when I get home. What do you mean by adapt from another one?
Edited by aust014, August 25, 2014 - 10:49 AM.
  • aust014
Posted August 25, 2014 - 11:12 AM
What did you use to mount the ignition, right now zip ties are holding mine on
  • MountainRider35
Posted August 25, 2014 - 03:43 PM
PO had a togle switch for the grey wire mod there which I didnt understand why? So I removed it a bolted the key in there.
  • RockerYZWR
Posted August 25, 2014 - 04:54 PM
Most likely because he read about somebody here doing it and thought it sounded cool. Just a guess!
  • stevethe
Posted August 25, 2014 - 05:12 PM
I use to have one it gives you a WR traction map and a YZ speedster map. Just for the price of the switch.
  • aust014
Posted August 25, 2014 - 05:40 PM
Thanks ill have to make that kind of mount
2012 wr450 headlight by donkeyballz
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  27 replies
Yamaha WR450F 2017 by Chris.GVS
Yamaha WR450F 2017
  • 0 reviews
New to the SM world by Kegger_92
Dirt Bike   Special Interest Forums   SuperMoto
Should i switch to a ktm 300 exc or xcw from a 2009 wr 450f by Tattoojunk
  • Hot  76 replies
Washington
The Teanaway is no BS! by Nuklhed
  • Hot  55 replies
