  • Instagram
Related Reviews
Yamaha WR400F 2000
Last review by twerth
Yamaha WR450F 2007
Last review by cbsander
Yamaha WR450F 2003
Last review by Dave in Illinois
Yamaha WR450F 2009
Last review by msowsun
Yamaha WR450F 2011
Last review by jtklein
Related Garage
Yamaha WR450F (2006)
Owner: Toad Atsma
Added on December 25, 2016
* * * * * 7 votes
What did you do to your WR today?
Yamaha WR400F Yamaha WR450F
4436 replies to this topic
  • SPLATT
Posted February 06, 2013 - 06:43 PM
Thats the first thing I replaced followed by a needed voltage regulator/rectifier.
So I started do the tests in the manual yesturday and the (resistance) pick up coil measured strange...
Then the bike wouldn't even run long enough to do the voltage tests ... so today I ordered
a Ricky Stator DC setup, hopefully its here by friday .
Didn't see that you had already did that.
  • Rodrigue
Posted February 09, 2013 - 06:15 AM
Today i have fitted new impeller shaft, impeller, seals and an oil and filter change after a water seal failure a coulpe of weeks ago. After a good ride today it seems the new seal has worked and there is no oil/water contamination so with any luck I have not warped the head or done any damage to the head gasket.
I have also fitted new mudguards and an e bay bargain of a Magura hydraulic clutch conversion which for the first time ever for a bargain works first time!
some photos
and the new (to me) clutch
  • Bandit9
    TT Titanium Member
Posted February 09, 2013 - 04:26 PM
Loaded the WR in the truck for the 2 hr drive to our trail system and worked trail in the am, then rode two loops after lunch with two of my best buddies. Dirt was very nice today on new S12's. It was like velcro.image.jpg
  • SPLATT
Posted February 09, 2013 - 04:33 PM
Finally took it out for a good trail ride since making it street legal. Now that I have a ride on the set up I need to make some changes. Gearing needs to go back to close to where I had it when it was off road only(don't plan on logging too many high speed miles I have a FZ1 for that),the MT21's got to go I just don't like them for most surfaces. The only place I do like them is on packed gravel without a lot of marbles on top. And finally need to re adjust the Rekluse EXP.
  • LucasLeader
Posted February 09, 2013 - 07:54 PM
Washed it, installed a new chain guide block and made a grab handle out of an old paracord bracelet.
Edited by LucasLeader, February 09, 2013 - 07:55 PM.
  • Bandit9, SPLATT and n16ht5 like this
  • Like This
  • n16ht5
Posted February 14, 2013 - 07:59 AM
went for a night ride. you can't see very well when your headlight is pointed at the sky at 40mph :)
  • Bandit9, SPLATT and revyrider like this
  • Like This
  • Bandit9
    TT Titanium Member
Posted February 14, 2013 - 07:06 PM
Ran across a few pics of myself on the 06 with my son just learning to ride.image.jpg image.jpg
  • mr2autoxr
Posted February 15, 2013 - 08:22 AM
Any tips on how to make one? I don't have any cord put I definitely need to put something like this on the front of my bike. Thanks!
  • LucasLeader
Posted February 15, 2013 - 09:37 AM
I just ordered some paracord and looked up youtube videos and whatnot online and went for it. Made a few for friends and some zipper pulls too. Paracord is cheap so buy extra.
  • still2smokin
Posted February 15, 2013 - 05:38 PM
I started it today ...and it actually ran :banana: :banana: :banana:
Last weekend , in an effort to solve my cutting out issue I installed a new Ricky Stator setup
the bike put up a good fight but I got it in there.
Got the lights all wired to a switch and and all was good.......started it up and 30 seconds later it died and wouldn't refire .
So there I was planning my suicide, and decided to pull apart the splice I did for the tach lead to +coil wire
( I used one of these )
Once I pulled it apart I saw the metal part of the splice had cut thru most of the coil wire that had maybe only
8 strands left intact . I hope this is the problem.
Edited by still2smokin, February 15, 2013 - 05:54 PM.
  • Bandit9
    TT Titanium Member
Posted February 15, 2013 - 06:07 PM
Way to stick to it. Those bolts gave me fits too. Hope she runs good for you.
  • n16ht5
Posted February 15, 2013 - 07:23 PM
used it to bring firewood down to the first fire of the year :)... summer is coming!!!
Edited by n16ht5, February 15, 2013 - 07:31 PM.
  • MANIAC998
Posted February 16, 2013 - 04:34 AM
I hope you've got it figured out. Still running?
  • LucasLeader
Posted February 16, 2013 - 07:54 AM
I would stay away from those splicers. I had one cut through a wire eventually and it was on there for years. Taking the extra time to solder it or installing some of those barrel plugs that Baja Designs uses would probably be best. I needed a quick fix since I was going the next day and don't have a soldering iron or any connectors to I just twisted the wires together really tight and put a good layer of heat shrink over it.
  • still2smokin
Posted February 17, 2013 - 12:57 AM
SIGH......It did the same crap ran perfect for a bit then just stopped......
So my buddy let me take his for a spin, after 2 months without riding I was not gentle to the
bike or myself. I got a lot of riding/adrenaline in, in a short amount of time thats for sure.
I really feel it is electrical, so that leaves me with my CDI , that my buddy tried on his bike in his garage already and it
ran fine , but I need to put his CDI on my bike and take it for a ride to really test. Hhmm how do I do that ?
I have got it ! I should get said riding buddy too hammerd to drive home and convince him to lock his bike
in my garage so it doesnt get stolen then swap CDI's ( he said it was cool ) . No that won't work ....or will it ??
  • Bandit9
    TT Titanium Member
Posted February 17, 2013 - 06:01 AM
Sorry that you are having this issue. Not much fun.
  • TheCape
Posted February 17, 2013 - 11:51 AM
I looked at All the snow melting and move the snow machines out of the way and drooled over the WR. Battery is charged up and ready to rip
  • mbha178
Posted February 17, 2013 - 01:26 PM
Just bought 07 wr250 today. Needs a little work. Forks need rebuilt. All free mods were done. Any advice on forks or general ownership.
  • mbha178
Posted February 17, 2013 - 01:39 PM
Took off the nut-buster Clarke tank, ADVmonster secondary LED, and front fender pack. redid some of the wiring loom too. That Baja Designs headlight is extremely bright
someone trade me your IMS for my Clarke!
How did you mount ur plate?
  • MXCRFDAD
Posted February 17, 2013 - 07:48 PM
All new graphics. Road for first time. Love bike. Mine is an 03
Yamaha WR450F 2017 by Chris.GVS
Yamaha WR450F 2017
  • 0 reviews
  • 0 replies
05 wr450 oil leaking from fuel tank mounting hole by gee-tee
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • 0 replies
Wr450f at higher speeds wobbles quite a bit by Turtlerider
  • Hot  28 replies
Show Us You 2016 WR450f & Mods by chelder
  • Hot  34 replies
