  • Instagram
Related Reviews
Yamaha WR450F 2016
Last review by bobkoch
Yamaha WR450F 2005
Last review by Kalamazoo
Yamaha WR450F 2008
Last review by chandic
Yamaha WR450F 2004
Last review by jtklein
Yamaha WR450F 2007
Last review by cbsander
Related Garage
Yamaha WR450F (2013)
Owner: 20 A
Added on January 16, 2017
* * * * * 7 votes
What did you do to your WR today?
Yamaha WR400F Yamaha WR450F
4437 replies to this topic
  • bluejuice
Posted January 08, 2008 - 02:49 AM
I purchased it! Had the AIS, fuel screw, throttle stop, Gray wire, and pea shooter all taken care of.
  • matt4x4
Posted January 08, 2008 - 04:28 AM
Painted the frame Saturday, clearcoated it last night.
  • jtn 06 wr450
Posted January 08, 2008 - 06:47 AM
new rear 5.6kg/mm spring, tonight new extended cables
  • jtn 06 wr450
Posted January 10, 2008 - 07:03 AM
new pro-motion extended cables all around.
removed clutch safety switch and hard wired across.
  • MojaveThumper
Posted January 10, 2008 - 05:04 PM
In the middle of replacing the :D :banghead: :busted: :D :ride: :D :D Water pump seals. Gotta friggin take off the sidecase for this. ARGH!!!!!!
  • redswr
Posted January 10, 2008 - 11:54 PM
replaced front fender... put after market engine plugs, ran about 4 quarts of oil through to flush it, disconnected the grey wire, and took the air snorkel off. tomorrow i need to take off the paddle tire and put my knobbie back on to test out the grey wire/air box mods.
  • tweav
Posted January 11, 2008 - 12:18 AM
so redswr have you rode your bike since you tiptoe in the sand?
  • redswr
Posted January 11, 2008 - 12:44 AM
not much... its been ran about 20min. ever since i used gas to clean out the inside of the case my oils been really creamy looking. i've ran 3 quarts through since then though so its hopefully cleared up. took the oil filter out on the last change and didn't any sand so thats good...
  • tweav
Posted January 11, 2008 - 01:20 AM
gas in oil does not = milky looking. oil gets milky with antifreeze in it. I would keep changing your oil after each ride and keep an eye on your coolant level . you may have a bad seal or gasket somewhere.
  • MojaveThumper
Posted January 11, 2008 - 07:06 PM
Finally got the oil seals in the water pump. Got it all back together with no leftover parts. :banghead: and no leaks. Knock on wood.
Motor even souns better. Think the stealer didn't have the header pipe installed all the way. Motor always seemed to lug a lot. Not anymore. :busted:
  • 2lcf
Posted January 11, 2008 - 07:40 PM
I removed my AIS, rejetted carb, and disconected grey wire...........took it for a spin on the street, luckily no cops around, and it lifts the front wheel even easier now...........can't wait to get it to the dirt...........
  • MojaveThumper
Posted January 12, 2008 - 06:40 AM
Don't for get to remove the snorkel under the seat and punch some holes in the side cover. She needs to be able to breathe with all that new fuel.
  • MojaveThumper
Posted January 13, 2008 - 04:00 PM
Just got back from an 8 mile ride. Not much but needed to stretch its legs after it being laid up for two weeks waitin on seals and the time to install them.
WOW factor is way up. Found that the header pipe wasn't fully installed from the dealer. Been riding like this for nearly 18 monthes. Guess the WR likes a little back pressure. :banghead:
  • SXP
    TT Titanium Member
Posted January 13, 2008 - 08:01 PM
Went to Phoenix for the SX and took the 07 with me. Came back with a AZ plate:busted:
  • yamageezer
Posted January 14, 2008 - 09:10 AM
I installed a Rekluse Z-Start Pro :banghead: :busted: :ride:
  • 2lcf
Posted January 14, 2008 - 03:31 PM
Thanks............I did that and the exhaust restrictor the FIRST day, even before she got dirty............I need and exhaust now...............
  • Thumper_Bloke
Posted January 14, 2008 - 09:08 PM
I put an '05 headlight with white front decal on my '04. IMO makes the front of the bike look "fresher". Oh yeah, i also had a great ride on her this weekend!!!!
  • STEPHEN G sv
Posted January 14, 2008 - 09:20 PM
where do you ride in az? Im in sv south of tucson.
  • Solo
    TT Titanium Member
Posted January 15, 2008 - 11:43 PM
Try this thread-
http://www.thumperta...ad.php?t=584546
Or-
http://www.thumperta...ad.php?t=588234
In the VERY active Southwest section-
http://www.thumperta...isplay.php?f=50
  • Ridon
Posted January 18, 2008 - 03:29 AM
I removed the grey wire today. I hope i'll feel a diference...
  • 0 replies
any reason why to get new Beta 450rr instead of wr450f ? by motf
Dirt Bike   Make / Model Specific   Beta
  • Hot  80 replies
Should i switch to a ktm 300 exc or xcw from a 2009 wr 450f by Tattoojunk
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  76 replies
Yamaha WR450F 2017 by Chris.GVS
Yamaha WR450F 2017
  • 0 reviews
Show Us You 2016 WR450f & Mods - last post by Super_Davee
  • 0 replies
