  • Instagram
Related Garage
Yamaha WR450F (2006)
Owner: Toad Atsma
Added on December 25, 2016
Related Reviews
Yamaha WR450F 2007
Last review by cbsander
Yamaha WR450F 2017
No reviews available
Be the first to review this
Yamaha WR450F 2014
Last review by BlueSmoke33
Yamaha WR400F 2000
Last review by twerth
Yamaha WR450F 2016
Last review by bobkoch
* * * * * 7 votes
What did you do to your WR today?
Yamaha WR400F Yamaha WR450F
4436 replies to this topic
  • shelbyguy
Posted May 25, 2011 - 09:14 PM
finished my custom dual exhaust on my wr today.
would love to see more pics of the header and such. how you got it all amted together?
i have a cr250r exhaust also and have been thinking about how much i miss the duals that were on my ktm smr...
  • allupinsydeyou
Posted May 26, 2011 - 06:12 AM
it is really a matter of just welding on the proper fitting to get the unit to mount to the stock header. i used the stock header and cut sections outta the stock exhaust. tack welded it all up to make it the correct shape. when i figured it was good, i pulled it off, TIG welded the shit together and called it a day. mig will burn to hot and blow holes right through the material.
  • Shred Jesse
Posted May 26, 2011 - 02:33 PM
Is there any benefit to having dual exhaust besides looks? It also seems like additional weight to me...
  • davidl9999
Posted May 26, 2011 - 09:30 PM
I'm still trying to figure out why one can hole is bigger than the other... :smirk:
Edited by davidl9999, May 26, 2011 - 09:48 PM.
  • allupinsydeyou
Posted May 27, 2011 - 07:37 AM
the only reason i can see for one hole to be larger in the exhaust is the pressure equalization values. if you have the pipe that has the ability to flow straight through than the second can will flow almost no exhuast and be relatively useless other than "bling" factor.
and as far as having 2 cans vs. only one.... i dont see any performance increase just yet since i cant ride it at the moment but i personally just like the look of it. and well... since its my bike... hahaha
  • redswr
Posted May 27, 2011 - 07:46 AM
you'll probably have to go with a couple 2 stroke pipes... having the 2 bigger mufflers like that won't give enough back pressure
  • allupinsydeyou
Posted May 27, 2011 - 08:20 AM
it seems to do fine on idle and putting around. i have yet to actually be able to take it out and open it up and get an idea of what i need to do with the jetting. ill post up when i get that solved and see what changes need to be made.
  • shelbyguy
Posted May 27, 2011 - 07:01 PM
my 560 made a little more power up top, and a bit louder.
i hate the way the mufflers look hanging past the number plate that would be the reason why for duals for me.
and yes, i just like the look of a pair of shorter cans.
:smirk:
sound clip? more pics? do iiit
  • CanadianWR450
Posted June 04, 2011 - 04:54 PM
Finally got it all put back together and went for a ride today.
Myler's came through and got my rad issue sorted out, and got me the correct set.
Have to say, they stand behind their customer service, because between shipping and customs charges from them to Canada, they didn't get much $$ out of this sale.
Those Supercools are some sweet though.
Before:
After:
  • gearhead86
Posted June 04, 2011 - 08:02 PM
Just installed a Clutch basket and primary gear from a yfz450 quad in my dualsported 2004 WR450.
The quad's basket has dampening springs to isolate the power pulses and shocks from the road between the engine and wheel. kinda like a cush drive.
I just took it for a drive and I would say it is definitely a noticeable improvement. There was much less vibration and on/off throttle transitions seemed smoother. There also seemed to be less chain slap and the engine sounded quieter.
I got the idea from haskell and maxpower. thanks guys
  • Sknight
Posted June 04, 2011 - 08:56 PM
Installed a Spal fan on the right radiator to help with my slow tail not moving enough air across the radiators, now it can sit and idle in near 100* heat without going past 200*.
I also installed a Staintune exhaust from a WR426 and gave it a rejet to match. Talk about a difference, between the two it's very smooth and picked up a lot of bottom end power. Far more than I expected.
  • redswr
Posted June 05, 2011 - 02:32 PM
finally picked up a battery for the 07 and took it for a quick blast up and down my street... on the way back got a face full of rad fluid cause the cap fell off :ride: not sure if i had just set it on there or didn't turn it all the way when i put it back on but i'm just glad i wasn't in the desert or woods when i lost it!
  • SPLATT
Posted June 05, 2011 - 02:57 PM
I rode mine.
  • irving762
Posted June 07, 2011 - 12:23 PM
Made some bar adapters 7/8" to 1-1/8" for my '92 WR200
  • The Hopper Show
Posted June 07, 2011 - 04:38 PM
dang good work! want to make me some? :ride:
  • allupinsydeyou
Posted June 07, 2011 - 06:45 PM
ripped her apart :ride:
  • redswr
Posted June 08, 2011 - 12:24 AM
watcha got going on there?
  • allupinsydeyou
Posted June 08, 2011 - 06:09 AM
destroyed threads on my crank. so new crank time. effin sad face
  • YamaLink
Posted June 09, 2011 - 08:48 PM
This is kind of a weird one. We bought a used 09 a few weeks ago. The usual deal where you find a few issues after the fact, most no big deal. But one thing bugged me when I adjusted the chain. Even though the marks were lined up I could visually see the wheel was WAY OFF to the right. Long story short, the previous owner had mis-matched axle blocks!
So today we went to the local dealer and put on new axle blocks for the WR.
  • pschiess
Posted June 10, 2011 - 12:54 PM
I finished doing my 2007 WR450f in white with new graphics and a dual sport kit.
2012 wr450 headlight by donkeyballz
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  27 replies
Yamaha WR450F 2017 by Chris.GVS
Yamaha WR450F 2017
  • 0 reviews
Valve Cover gasket keeps blowing by pbcrazy9898
  • Hot  29 replies
Washington
The Teanaway is no BS! by Nuklhed
  • Hot  55 replies
Just curious how much i could get for my bike not intrested in selling though by mikerussell97
  • Hot  35 replies
3 user(s) are reading this topic
1 members, 2 guests, 0 anonymous users
    still2smokin
