  • Instagram
Related Garage
Yamaha WR450F (2008)
Owner: Zippo638
Added on December 02, 2016
Related Reviews
Yamaha WR450F 2015
Last review by Ken S
Yamaha WR450F 2004
Last review by jtklein
Yamaha WR450F 2003
Last review by Dave in Illinois
Yamaha WR450F 2017
No reviews available
Be the first to review this
Yamaha WR450F 2012
Last review by Ptch5636
* * * * * 7 votes
What did you do to your WR today?
Yamaha WR400F Yamaha WR450F
4430 replies to this topic
  • byggd
    TT Titanium Member
Posted April 26, 2011 - 07:33 AM
I wanna move to the States!
Sooo much after market gear
True but down-under you can buy a plated WR450 :thumbsup:
  • jshepherd61
Posted April 26, 2011 - 01:43 PM
Ok so I just bought a new 2009 WR450F unfortunately I'm a fuel injection tuner been a while since I worked on a tin can (carb). I started to ask a few questions after I did the free mods; air box, new FMF pipe, AIS GYTR, R&D Powerbowl 2, R&D Acc pump, Grey Wire, K&N filter. On how to jett this thing, I live in Colorado and ride between 6500 - 11000'. So after searching and reading all of the posts especially the one directed at the newbies to check the posts, threads and sticky's. I've cut and pasted all of the prevalent information and have come up with some results which confuse you even more! My findings, Oh and by the way my last job was EFI tuning for Esteban Guerrieri in the IRL Indy lights so I'm not trying to be a SA just looking for help. Back to what I've found in the WR450 Intake - Jetting / Fuel Injection and Jetting table;
ALT - 8,000'
Main jet: ranges from 150 to 168
Pilot jet: ranges from 40 to 50
Pilot AJ: ranges from 65 to 85
Leak Jet: ranges from 45 to 55
Starter Jet: ranges from 58 to 67
Fuel Screw: 1 1/4 to 2 (only consistent setting)
Needle clip depending on type but all using the GYTR anywhere from 2 to 4
Ok these are the variances for the same bike same 6,000 to 10,000 at 70 - 90 degrees. I know ever bike is different but not as much as these variances and they all run great! Can anyone help me with a good starting point that has recorded the AFRs and VEs in these altitudes?
  • Shred Jesse
Posted April 26, 2011 - 09:35 PM
That's how epic my high side was. Bark buster: Demolish. Lever: Bent. Grip: sawn through. Fat bars: Somehow unbent!
My body bore the brunt of the rest of the crash.
  • damohurley
Posted April 26, 2011 - 11:37 PM
This is a rookie question, I bought a 2004 WR450 and I am slowly learning the ropes.
Question to the pros out there, how do I tell if my clutch is on its way out. currently when the bike is swichted off and I put it in first gear and hold the clutch in, it will not roll. I do not notice this problem when bike is on and in gear. Is this a bad sign?
Thanks for any help. i did search around a bit but turned up nothing.
On topic, I gave it a bath and lubed chain.
  • davidl9999
Posted April 27, 2011 - 08:36 AM
It's typical for WR's with new clutches to stick; a change to some Honda parts (that are thinner than the Yamaha parts) fixes that if you can't stand the binding (which should go away over time). Also if the basket is worn, the plates will stick on the worn-in grooves on the clutch basket fingers; the solution there is to smooth the grooves or replace the basket if the wear is excessive.
  • WRF Woods Weapon
Posted April 27, 2011 - 08:55 AM
Every time I visit the US my interest is to purchase a bike...i have to spend sometime to browse through this entire thread , its funny as a biker you pick up odds and ends and so much tips on how to get things done. from these article..very interesting eh!
  • redswr
Posted April 27, 2011 - 11:35 AM
Well if your in California down towards LA check out Berts Mega mall... They have every make and model bike along with a parts store that's bigger than most normal bike dealers. They've got boats too :thumbsup:
  • tribalbc
Posted April 27, 2011 - 05:47 PM
Railed her for a couple hours at the track. Was feeling it :thumbsup:
  • Shred Jesse
Posted April 29, 2011 - 10:34 AM
Bark busters swapped out, new rear tire, re-tightened steering stem bearings (came loose since install a while ago) and sorted out the bike in general. It's ready to rip!
Next up:
Next weekend I'll be installing my James Dean Jetting Kit, throwing on some street tires for my bike... and DYNO TUNING it! WOOHOO! This will ensure that I really know what's going on with my bike! I also might be dyno tuning my street bike. More on that to come though...
  • shelbyguy
Posted April 29, 2011 - 10:49 AM
Next up:
too bad you arent local. ive got a dyno pretty much all to myself this sunday :thumbsup:
when you gonna ship me that power bomb header of yours?
  • Shred Jesse
Posted April 29, 2011 - 10:51 AM
too bad you arent local. ive got a dyno pretty much all to myself this sunday :confused:
When you buy it for $300 :thumbsup:
  • The Hopper Show
Posted May 01, 2011 - 09:25 PM
rode it! had a great maiden voyage! :confused:
did have a stupid slow get off. one of those loss of momentum/balance kind of things. bent my brand new brake lever and gouged the front fender pretty good. :thumbsup:
but other than that:thumbsup:
i was pretty darn impressed with it for being a stock bike that has not been uncorked. felt great to ride today. need to play with the rear shock settings a bit. little too much rebound i thought. actually, i don't know if i will mess with the performance too much. how much does doing the pea shooter and air box and rejetting really affect the bike? it felt great. smooth, and managable power. what can i say though, i am used to riding 2 smokes. this thing was night and day difference in how usable the power was. should i still do these "free" mods?
anyone know an easy way to bend levers back into shape?
  • davidl9999
Posted May 02, 2011 - 07:48 AM
Yep. The WRs need to be uncorked and jetted before they'll really perform. Do the free mods and jet your bike.
  • YamaLink
Posted May 03, 2011 - 08:59 AM
Re-tapped a 6mm bolt (with 8mm head) on a used 09. The previous owner must've been able to get the bolt in one...last....time, and got it to hold. Should've known by looking at the rubber piece which the bolt/washer went into: squished and annihilated! So when I went to put the bolt it the threads would not take. Knew it wasn't that bolt because the same sized bolt from elsewhere would not go.
A simple 6x1.25 fixed it, but it's a total inconvenience when it happens. Everyone is riding and you're stomping around looking for that tap & die set.
  • ofgofg
Posted May 04, 2011 - 07:18 AM
Every day I am trying to finish off small details on my supermoto. Every day brings new challenges! Yesterday, I wired and attached the 2009 style integrated tail light,, then cobbled up a ghetto license plate holder. Today I get to hook up the turn signal portion of that light and redo the license holder.
  • rholbrook
Posted May 04, 2011 - 09:56 AM
I really like mine. It already has the holes in it for the small LED blinkers. PM me your email address if you want to see pictures and if you want to know where I got it. I cant attach pictures, the option isnt there for me.
  • redswr
Posted May 05, 2011 - 04:45 PM
took the carb off the 99 to diagnose what i need for it... i can't seem to really find what i need to buy though see what you guys think (red pieces are lawn mower parts)
  • davidl9999
Posted May 05, 2011 - 07:54 PM
AP cam and lever. You can get that off a junked '99 carb if you have a motorcycle junkyard nearby or someone's selling a parts bike cheap. Maybe one of the rebuilders can sell you a used piece. Here's a 'fiche from the TT store: http://shop.thumpert...=1999&model=897
Pretty sure that you can't order that particular part (un-numbered in the 'fiche).
  • redswr
Posted May 05, 2011 - 10:04 PM
i don't see it at all on there... i see the lever but it doesn't show it going into anything
  • davidl9999
Posted May 05, 2011 - 11:23 PM
Sometimes those drawings are crap. The cam is hidden on the back of the carb. Since it's not something that you can buy, it's not shown. It fits right where that red thing is on that shaft with the spring. You can just barely see where the bottom half of the throttle linkage goes behind the carb where the AP timing screw is (broken off on your carb); and, of course, not shown on the diagram. :thumbsup:
Should i switch to a ktm 300 exc or xcw from a 2009 wr 450f by Tattoojunk
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  55 replies
New to the SM world by Kegger_92
Dirt Bike   Special Interest Forums   SuperMoto
Wr450f at higher speeds wobbles quite a bit by Turtlerider
  • Hot  28 replies
Kickstarter Noise by JohnClaude
  • 7 replies
Show Us You 2016 WR450f & Mods - last post by Super_Davee
  • 0 replies
