Removing Front Sprocket
14 replies to this topic
  • mxpanda
Posted July 19, 2007 - 07:49 AM
Can anyone tell me what size socket I need to remove the nut to get the front sprocket off my bike. Its a 06 450, don't know if that matters.
  • opie
Posted July 19, 2007 - 10:20 AM
I believe I used a 32mm but I'm not sure. If I was home I could look in my toolbox to verify. Hope this somewhat helps!
  • jim598
Posted July 19, 2007 - 04:23 PM
its the same as your rear axle nut
  • yz4fun
Posted July 19, 2007 - 07:28 PM
I Think A One Inch Socket Will Fit
  • ben_suhard
Posted July 19, 2007 - 09:04 PM
Yep, what he said, I use a 27mm.
  • 1BLUEsky
Posted July 19, 2007 - 09:10 PM
ditto 27 mm
  • mxpanda
Posted July 23, 2007 - 06:46 AM
Thanks for the help
  • rickallen124
Posted July 23, 2007 - 11:10 AM
You'd better have an impact sockect/ wrench to get it off though.
  • Ga426owner
Posted July 23, 2007 - 12:45 PM
yep cause trying to hold that rear tire from spinning totally bites.....:foul:
You can however remove it with a very heavy person sitting on the bike with the rear brake on while you wrench :prof:
  • ben_suhard
Posted July 23, 2007 - 01:00 PM
Another way, although somewhat controversial, is to jam something in between the rear sprocket holes and swingarm.
Posted July 23, 2007 - 01:01 PM
A sturdy 1 x 3 laying across the swing arm through the spokes works real well, too, assuming you haven't removed the chain already.
  • Ga426owner
Posted July 23, 2007 - 01:06 PM
at last a better way than my old fashion stick the long handled screwdriver in the front sprocket under the cases method....:foul:
Grey no problems bending spokes? 1 x 3 all the way up to the rim, I assume?
Posted July 23, 2007 - 01:22 PM
That's the key to it, yup. :thumbsup:
  • deleonjo
Posted July 23, 2007 - 09:56 PM
27mm-Engage Rear Brake while chain is still on.
  • Yamahafan
Posted July 24, 2007 - 05:38 AM
1) Put in gear before engaging brake.
2) Remember what a pain-in-the-azz it was to take off and put some assembley lube on the spline, sprocket, threads and nut before reinstalling. You don't have to worry about the nut coming off because it has a bent-over retaining clip/washer thingey. I also like to use a wire brush to clean the whole area before installing the new sprocket.
Motocross
  • Hot  491 replies
  • Hot  47 replies
  • 0 replies
  • 5 replies
