Any kind of rear footpeg setup for these bikes?
2 replies to this topic
  • 2000WR400
Posted May 25, 2000 - 07:46 AM
My girlfriend is buggin' me to bring her out for a ride. I don't think she will want to more than once though, I don't think she knows she has to ride on a 2x4. Anyone have a rear peg setup or know of one I can try? Thanks
  • Guest_Guest_*
Posted May 25, 2000 - 08:01 AM
I think Baja Designs still sells a kit to put rear footpegs on a XR600. It consists of a steel plate you weld to the subframe, and a set of XR650L passenger pegs you bolt to the plate. I don't know if this would work on a WR or not.
I do know that the seat will be no where near as comfortable as an XR600 for the passenger.
Roy
  • Guest_Guest_*
Posted May 30, 2000 - 01:51 AM
Yes Baja do a kit, it does require you to weld a bracket to chain side of rear subframe but works great and is easy to remove when you're not with 'her in doors'
I also used the plastic mairer frame guards, they can easily be adapted to fit with passenger pegs on.
