keep back tire on the ground
4 replies to this topic
  • laker
Posted July 18, 2007 - 07:27 PM
I have a 98 650l and i have a hard time to keep the back tire on the ground when im driving on or off road. Like when im on road and drive over a manhole cover. I feel the back tire come up off the ground and then back on the road. Not good on a corner and off road it has a lot of bounce. I have tried to adjust the back shock and the rebound nothin changes to much any help would be great
  • pigryder
Posted July 19, 2007 - 03:42 AM
You could have a blown or weak shock, is there any sign of fluid around the shaft seals on the shock?
  • Denn10
Posted July 19, 2007 - 05:56 AM
your suspension is prolly off between having the correct spring for your weight and your sag setting, and its prolly been a few years since youve had the oil changed all this will make your suspension work correctly.
  • laker
Posted July 19, 2007 - 08:14 PM
thanks for some tips i will check . Could the spring be to tight
  • laker
Posted July 19, 2007 - 08:16 PM
thanks i will check the oil . Could the spring be to tight
