BD D/S kit question?
11 replies to this topic
  • TrailRiderXRL
Posted July 18, 2007 - 04:05 PM
My XRR has a BD D/S kit. I broke my head light case then the bulb broke from water contacting it while hot. My question is: does the blown headlight bulb affect the tail light/ brake light? Just noticed that my tail light/ brake light is not working. It was working prior to the headlight incident. According to this schematic it shouldn't cause the tail light to quit!
http://www.bajadesig...kickstarts).pdf
  • Coolidge
Posted July 18, 2007 - 04:28 PM
I dont believe it would affect t/lamp. I also have a BD kit. (XR600R) But my T/L bulb goes out all the time assumably from off road/vibration?
  • dzrtrat1111
Posted July 18, 2007 - 09:13 PM
i had nothing but problems with the stock BD D/S tail light assembly.. it would constantly go out because of bad connection do to vibration, and my XR only see's the street.. I changed it to the Baja Designs LED tail light, which requires using a MX fender, and it completly solved the problem. Plus the LED is way brighter, and that's really good for being seen! total cost for the LED tail light and the MX fender was around $100 or so.
  • hypersthenos
Posted July 19, 2007 - 09:05 AM
My guess is another connection came loose during your last crash. Make sure to check all the connections. Did the switch assembly get any damage? These switches are pretty fragile. You can dissassemble the switch and check for internal damage fairly easily. My switch has enough wear that it will not operate the tail light in the first position as the printed circuit has worn through. I agree that the BD LED tail light assembly is a good product but before mounting it you should remove the LED light assembly from the bracket & smear some clear silicone around the back edge to prevent water/dust intrusion into the electronics.
  • kellismechanic
Posted July 19, 2007 - 02:51 PM
Did you check the fuse in the power wire? could have shorted and blown the fuse
  • TrailRiderXRL
Posted July 19, 2007 - 07:04 PM
No not yet! Would it be near the battery pack?
Must have been cracked by a roost! Didn't crash!
  • Coolidge
Posted July 20, 2007 - 07:22 AM
Yes, it would be near battery pack, under seat. Good luck
  • martinfan30
Posted July 20, 2007 - 09:31 AM
mine has been flawlessss.
  • TrailRiderXRL
Posted July 22, 2007 - 12:29 PM
I'll check tonight!
Thanks
  • TrailRiderXRL
Posted July 22, 2007 - 11:35 PM
Bulb was burnt!
Thanks for the help guys.
  • TrailRiderXRL
Posted July 23, 2007 - 12:07 PM
Should have asked, what bulb do I need to replace the burnt one with?
  • bosshog
Posted July 23, 2007 - 05:51 PM
I replace my tail light bulb with an LED bulb and had no more issues with blowing rear bulbs. If you have a good Automotive Parts store near you or I've even seen them at Walmart. I believe it is a Dual Intensity 1157 bulb in the Baja Designs kit. Any LED bulb that will work should say "replaces 1157 bulb" or " 1157 series " This was one of the few flaws with the B/D kit but it was easily fixed.
bosshog
  • Hot  186 replies
  • Hot  29 replies
Washington
  • Hot  32 replies
  • 9 replies
  • Hot  60 replies
