Hey Kevvie - Here is the Throttle Stop info
4 replies to this topic
  • Mitch_from_Oz
Posted May 23, 2000 - 04:08 PM
Here you go kevvie... from the archives
After some reading I decided to put my throttle stop back in, but guess what? I lost it! Since you cannot order the part from a dealer, here is how to make one.
Parts Needed: 1 M4-0.70x20m bolt, 1 M4-0.70 nut, JB Weld (Super glue may work)
Take the nut and screw it approximately 4mm onto the bolt (4 mm of bolt sticking out). Apply JB Weld to the nut and bolt on the side of the bolt where the
bolt head is located (long side). Let dry for about 24 hrs. Next, cut the head off of the bolt and grind the bolt down until there is approximately 9mm of bolt left
from the edge of the nut to the end being ground down. Put some lock-tight on the threads (short end) and install on carb. File down if necessary until the slide
opens up all the way. You're done.
Dimensions (in sections): 4 mm of bolt (part that screws into carb) 2 mm of nut (thickness of nut that I used) 9 mm of bolt (end of which stops slide movement)
15 mm Total Length from end to end
  • Mitch_from_Oz
Posted May 23, 2000 - 04:12 PM
Hey brother.
Email me your phone number again.. I seem to have misplaced it.... supermotard_99@yahoo.com
Mitch
  • Kevin_in_New_Hampshire
Posted May 23, 2000 - 05:18 PM
Hey Mitch,
My # is 603-942-7105. I am starting mids tomorrow night. I work from 9:30pm - 7:30am eastern standard (U.S.) time.
So let me get his straight. The total exposed bolt, including the 2 mm nut is 11mm. Then there is 4 mm of bolt screwed into the carb body. Is this correct?
  • Bryan
Posted May 23, 2000 - 05:58 PM
Alright! Time to start flooding Kevin with obscene phone calls.
Nevermind, he might like it!
Bryan...
Posted May 24, 2000 - 02:59 AM
The obscene phone calls are quite fine and welcome. I only ask you have a woman do it and make sure the calls are "Dirty"! :)
