coolant leak (weep hole)
4 replies to this topic
  • spencerspencer
Posted July 17, 2007 - 07:32 PM
I rebuilt my water pump in my 98' wr400fk. Oil seals, bearings, o-ring, and impeller shaft. Put the bike back together drove around for a minute and still leaking. Any ideas as to what I might have done wrong, or what I should look for?
  • clark4131
Posted July 17, 2007 - 09:19 PM
You likely put the seal in backwards or nicked it on the way in...SC
  • face_plant
Posted July 18, 2007 - 11:40 AM
yup, and since mine took a poop today i will find out if i made the same mistake P
  • Oasis_Flame
Posted July 18, 2007 - 01:17 PM
Yep, been there. The water seal is in backwards, be easy on getting it out you be able to re-use it. Leak will go away when you flip the seal. :thumbsup:
  • spencerspencer
Posted July 19, 2007 - 03:07 PM
Like Butter Thanks For The Advise!
