fuel mileage
5 replies to this topic
  • HGaither
Posted May 15, 2000 - 06:12 PM
does anyone know how many miles you can get out of the yz tank filled to the rim?
  • Mike_Hall
Posted May 19, 2000 - 05:13 AM
No, but I can get about an hour and and a half doing a fairly open enduro on my '00WR (8 ltr tank - european spec) at a reasonable clubman pace. Should be able to work out a (very) rough milage from that!
Mike Hall
  • RodH
Posted May 20, 2000 - 12:21 AM
I did 91kms today and was on reserve for a fair while, so when I got home I took the cap off and had a look and there was no fuel are the petcock, so that explained the last few kms of spluttering. I had the tank of to check the plug, so I tip the remaining fuel from the tank, and there was exactly 200ml left. So 7.8lt went exactly 91kms.
RodH Canberra, Australia<A HREF="http://www.400thumpers.oz-au.com" TARGET=_blank>
400 Thumpers Australia</A>
2000 WR400F See Photo's and Modifications
  • Jeff_in_AZ
Posted May 20, 2000 - 09:22 PM
I usually get about 35 miles to a gallon of gas (except in the dunes where it drops to around 17).
  • Guest_Guest_*
Posted May 21, 2000 - 12:02 PM
I have a Canadian 00WR400 and got about 150 Kms ( which is roughly 90 miles)to a full tank and completely ran it dry on reserve as well. This was on logging roads and tight trails. I believe it is a 12 Litre tank ( 3.17 U.S. Gallons). Hope this helps, Marco
  • Steve_Morgan
Posted May 22, 2000 - 11:15 AM
My WR with WR timing, 172 main, 45 pilot, open intake/exhaust, & stock gearing, gets 27 mpg on hard packed surfaces. I've heard about 20-25 mpg in the desert sands...
