1 reply to this topic
  • Kyle
Posted May 21, 2000 - 09:26 PM
I just measured the rear sag per the manual and the difference is 5 inches not the recommended 3.5 to 4. I weigh 185 with full gear.
Question is, to decrease this difference would I loosen the adjuster to decrease pressure on the spring? Also any idea where to find a tape measure in mm. instead of inches?
Dougie I will be following your progress on here with the suspension deal, I too am getting interested in this.
Thanks all,
'00 WR, Renthal bars, Cycra hand guards, throttle stop cut,for now everything else stock
  • Kevin_in_New_Hampshire
Posted May 21, 2000 - 10:03 AM
You want to turn the collar to push up against the spring, NOT away from the spring. That would be counter-clockwise if viewed from above.
To convert inches to metric, there are 2.54cm (25.4mm)per inch. Multiply your inches by 25.4(mm) to get your answer.
[This message has been edited by Kevin in New Hampshire (edited 05-21-2000).]
