Whey Protien
13 replies to this topic
  • 250Nasty
Posted 16 July 2007 - 11:16 AM
What is it, i know people that lift and such take it, mix it with milk or somthing, but what is it, just a proteien supplement?
  • georgeforeman
Posted 16 July 2007 - 02:15 PM
protein builds muscle. when you work out it helps muscle tissue recover and grow
  • yitsock
Posted 16 July 2007 - 06:04 PM
Yep, it's a protein supplement. It's very hard to get the required amount of protein a day with food. If you're lifting hard you should at a minimum take in one gram of protein per pound of body weight. (145 lb guy should eat 145 grams protein a day, preferably more).
There's a lot of forums out there on fitness. search and read up! Diet is the most important thing when it comes to gaining size.
  • Pornstar
Posted 16 July 2007 - 07:10 PM
Its one sourceof protein. They also sell protein shakes from egg or soy. Whey is better source of protein than the other two i mentioned.
Protein intake doesnt make you bigger/stronger if you don excercise accordingly.
  • marshmello1
Posted 16 July 2007 - 07:17 PM
Yep whey protein is basicly the ultimate pre and post work out supplement.As I understand it, the wehy sinks into your stomach lining quicker than any other protein so recovery time is minimum.
You will gain weight reall quick if your going to mix it with vitamin d-milk.
gain weight you need your body weight in grams of protein time 1.5
So if you weigh 150, you would need 225 grams of protein.
If your looking to get cut and maintain your current weight you need you body weight in grams of protein times 1
so if you weigh 150 you should take in 150 grams of protein.
Do yourself a favor and sign up at bodybuilding.com
Mike
  • rotation3x
Posted 17 July 2007 - 09:59 AM
I think I might get some of that!!
  • Salt n Pepper
Posted 18 July 2007 - 07:47 AM
Be careful with these protein supplements, they are fine if you are taking them and exercising accordingly. My buddy uses protein supplements and lifts weights day in and day out, if you dont lift while taking this stuff its doing you no good. To much protein is hard on your kidneys though, if you use this just try not to ingest to much protein from other sources.
  • Brumy 55
Posted 18 July 2007 - 09:21 AM
For everything that is out there Whey is probably the best and most simple form of supplements simply because it doesnt have all the extra crap they add to products like creatine which just basically gives you water weight and amounts to jack. So if your looking to be gaining muscle mass then yes Whey is the best way to go because there are no short cuts.
  • 250Nasty
Posted 18 July 2007 - 05:06 PM
Mike
Thanks, what if your trying to cut but burn some fat while your at it? Or tone i should say?
  • kx_rider53
Posted 18 July 2007 - 06:32 PM
I take whey protien as a supplment. I lift and do cardio regularly. It really doesnt taste that good (at least the one i got). I try and eat 5 smaller meals per day. I dont have a hard core diet, just no snacks, and try and eat good carbs. I feel that i still need some fat intake, and ill get that from milk, peanut butter, etc. Just my own outlook on the whole thing.
  • tagger
Posted 18 July 2007 - 10:44 PM
dear lord, do a google search...
  • dmoney1074
Posted 30 July 2007 - 04:57 PM
Just remember a normal human body can only assimilate ~32g of protien in one sitting, so some of these 60g protien shakes are pointless,,,
  • Heckler
Posted 30 July 2007 - 05:58 PM
You will want to take some Whey protein before you workout and then again immediately afterwards with some simple carbs (like an apple or bananna) the carbs will aid in the delivery of the protein to your muscles.
You want to take a Casein protein in the evening before bed to feed your muscles while you sleep.
Whey protein digests quickly, thats why you want it pre and post workout when you need it fast to repair the damage you did working out.
Casein digests slowly and will last to feed your muscles while you fast (sleep) Cottage cheese is an excellent source of Casein, a cup of low or non fat cottage cheese before bed is what most of the pro bodybuilders eat before bed, if you can handle the taste...
  • Way Fast Whitey
Posted 30 July 2007 - 06:10 PM
i just bought a huge tub of whey protein today to try up my protein intake. i lift weights and do cardio 6 out of 7 days a week so i feel it will help me along. everybody says its so good, i just wanted to see for myself. i made a smoothie and put one scoop in(17g of protein) and it tasted ok, tomorrow i'll try it with a big glass of milk.
