WR450 Gearing change 14/51 or 14/52?
7 replies to this topic
  • dazzabb
Posted July 16, 2007 - 01:25 AM
I want to lower the gearing slightly on my 450. We do a lot of 1st / 2nd / 3rd gear riding.
Will going up one tooth on the rear sprocket make enough difference?
Anybody gone up a tooth on the rear and then wished thay had bought a 52 tooth instead?
  • Gandalf_WR450
Posted July 17, 2007 - 12:57 PM
To explore, try throwing a 13T on the front- its a cheap and fast way to experiment. Gave me just what I wanted for tight trails.
  • ErikBeeb
Posted July 18, 2007 - 01:51 PM
A one tooth change on the rear sprocket is only about 2% difference. Doubtful you could even tell the difference.
One tooth down on the front sprocket is about 7.8%, or the same as about 4 teeth on the rear sprocket. More significant, and cheaper/easier to try.
My bike came to me with 14/52, but I dropped it to 13/52 because I do a lot of slow rocky tight trail stuff.
Posted July 18, 2007 - 04:14 PM
I dropped from a 14 to a 13 on the front and it made quite a difference.
  • SID013
Posted July 18, 2007 - 04:55 PM
Hiya, I have played around a bit with sprockets & went 13/51 which was great for tight snotty trails & hill climbs but no good for open track. I then went back to 14/50 & while it is not as snappy off the mark it is still usable. I may still experiment with 14/51 yet but try this link which has a gearing calculator & can give you speed comparison in each gear by mucking around with the sprocket ratio's.
Hope it helps.
  • PaulButler
Posted July 19, 2007 - 04:19 AM
Great Information guys - I was wondering how to gear down for the tight trails myself.
  • canyonclimb
Posted July 19, 2007 - 09:47 AM
I went from a 14/50 to a 13/50. I mostly trail ride and this change made all the difference for me. You can crawl up anything. The low end is really nice for tight technical stuff.
Canyonclimb 2004 wr450
  • dazzabb
Posted July 19, 2007 - 11:45 PM
Thanks for the suggestions.
I'm gonna give the cheaper option of a 13 tooth front a try first, then if that feels too low I'll think about changing the rear.
