Stealth turn signals
10 replies to this topic
  • PROWLER 58
Posted July 15, 2007 - 03:20 PM
I have seached and didnt find what I was looking for. Ive installed a dual star mirror,a brake light switch and now I need a very small set of turn signals for the back only(I think that will make me legal).What I did find was turn signals with no switch.I need a complete kit with wiring,handlebar switch and everything else to make it work.I also want it to be very small. Has anyone installed something like this on a 07 WR450 ? thanks
  • Birdy426
Posted July 15, 2007 - 07:09 PM
I don't think you will find a "turn signal kit". You will have to build your own.
Try these guys for switches and small turn signals.
http://www.kandstech.com/
  • PROWLER 58
Posted July 16, 2007 - 02:39 PM
Thanks, Ill call them. Still , Ill bet someone out there sells a kit. ?
  • PROWLER 58
Posted July 17, 2007 - 01:02 PM
Im still hoping someone out there has some more info on this. thanks bob
  • Merlin450
Posted July 17, 2007 - 02:45 PM
I don't know how well you can see the ones I (sky blue camos) used, they are very small and don't stick out past the tag. Used the same ones on the front, from K&S. I'll try and upload a better pic.
  • PROWLER 58
Posted July 18, 2007 - 01:10 PM
I cant see your turn signals on your picture.Id like to see your set up. How did you do the wiring and the handle bar switch ? thanks bob
  • eissinger4
Posted July 19, 2007 - 05:13 AM
Try this guy. He can custom build you anything you want, and his prices aren't too bad. Just get ahold of him through Ebay and tell him EXACTLY what you want and he'll build it for you....
http://cgi.ebay.com/...sspagenameZWDVW
  • face_plant
Posted July 19, 2007 - 11:40 AM
http://www.wheelingc...egory&cat_id=72
and he is upstairs and if u need help i can give you first hand help
and the drc kit is very cheap
  • Merlin450
Posted July 19, 2007 - 01:37 PM
Posted ImagePosted ImagePosted ImagePosted Image
1 - Handlebar switch w/flash to pass, horn, hi & lo, lights on/off. Needed to raise the hot-start to clear the switch.
2 - Plastic tag holder from my toy hauling trailer. The rear signals are attached to this.
3 - Front signals are the same as the rear, very small.
4 - Mounting bracket.
Switch has seperate hot wires for the headlight, horn ands ignals. HL is still AC and everything else is running on DC. Hydraulic pressure switches are used F/R. Brake and tailights are already wired just doesn't have the switches. Same for the headlight, needs a hi lo switch.
  • eissinger4
Posted July 20, 2007 - 01:09 PM
Alright, where did you get that hot start spacer and the brackets for the front signals??????????
  • snakesausage
Posted July 20, 2007 - 04:44 PM
The Edge-2 is a very small and well-engineered taillight with the optional turn signal setup. They have a wiring harness and front blinker mounts too.
U.S. distributor:
http://www.wheelingc...&cat_id=72#2442
Company website:
http://www.drcproduc...edge/index.html
