2007 WR450F - 52T rear sprocket?
12 replies to this topic
  • Fredtech
Posted July 13, 2007 - 08:49 AM
The standard bike as a 50 Teeth rear sprocket with a 14T front.
1- Did anybody tried a 52T? (i want to do more wheelies :-)
2- WIll the chain be long enough and how can you calculate that?
Thanks in advance.
  • muddyken
Posted July 13, 2007 - 08:57 AM
go down one tooth on the front and this is the same as going up three at the rear and much cheaper.
this is the best mod in my opinion for improving acceleration to pick the front end up
going up three teeth at rear or down one tooth at the front will still allow you to use your original chain
  • SurvivorMan
Posted July 13, 2007 - 10:01 AM
my 07 came with 50 tooth rear but had a 13 tooth front???? 1st gear was way too slow, even for super tight bushwacking and there was a lot of engine breaking. so i put on a 14 tooth front with stock 50 rear and now the engine breaking is much less. i guess it all depends on what type of terrain you ride. 1st gear now pulls harder on hill climbs, with the lower gearing, 1st would just spin loose on really low traction areas, higher gearing makes the motor pull and lets the tire stick a little longer (this is on the really slow technical slippery type hill climb)
  • SXP
Posted July 13, 2007 - 11:45 AM
Thanks in advance.
Standard front in the US is 13 teeth.
  • SJMC_DON
Posted July 13, 2007 - 02:04 PM
I found the 13 / 50 combo was to tall, I prefer to ride single track in 3rd gear using the wide ratio tranny I can lug it and wick it up to run it out with out alot of shifting. I just got a 12T front but have not yet installed, but 1T in the front is equal to 2.5+T in the rear.....
  • Matt James
Posted July 13, 2007 - 06:04 PM
I've been running a 12T on WR450 07 most of the spring. Like SJMC Don said it works real good in 3rd on single track. I'll go back to the 13 for winter desert riding, but single track the 12 really shines. It would take almost 4 T
on the rear to equal the 12 (50/13=3.84)
  • zukrider
Posted July 16, 2007 - 07:36 PM
I have thought about getting a 12t for my bike but have been warned about it being hard on the chain because of the tight radius not sure though
  • JSanfilippo
Posted July 16, 2007 - 09:54 PM
Wow I'm interested by the responses on this thread. I find the 13/50 to be perfect. Its low enough for the 1st/2nd gear tight stuff but its got enough legs to rip too.
  • simon@vic
Posted July 16, 2007 - 10:04 PM
52 works fine
  • tino79
Posted March 29, 2009 - 09:33 PM
what would the top speed be if i go one tooth down on front?
  • JSanfilippo
Posted March 29, 2009 - 10:06 PM
According to the spreadsheet I was just messing around on going down a tooth on the front lowers the top speed about 8 mph. Depending on the surface that means the top speed could be anywhere from 80-88 mph. That same spreadsheet says 4 teeth on the back has roughly the same effect as 1 tooth on the front.
  • chevytrkn1
Posted March 30, 2009 - 03:59 AM
i installed the 52 on the rear of mine, the chain will fit but barely. I have not got a chance to ride it much with it yet though
  • klossWR450
Posted March 30, 2009 - 08:11 AM
I had 14/52 on my 07 , wheel up just by accelerating in 1st 2nd and on near empty tank in 3rd, top speed 142 km/h about 90mph, loved it
