'05 WR 450 starting motor problem
7 replies to this topic
  • paulkimson
Posted July 13, 2007 - 04:30 AM
Hello guys,
I have a problem with starting motor. My WR450F was parked for a year and when I want to start the engine, I have to use starting motor too much.
Due to excessive use of starting motor, it starts making lots noise a few weeks ago and at last, today, I cannot start the engine even with kick starter.
Do I need to change starting motor as assembly or just change brush set?
Please help me!
  • jerryls
Posted July 14, 2007 - 10:39 PM
Hmmm. You need to figure out why the bike won't start with the kickstarter first. Once you get that straightened out.....
My original starter quit working after 3 years. During that time, I always used the starter, never really touched the kickstand. I tried replacing the brushes, resoldering the wires, etc, etc, but it didn't help. I think I just wore the poor thing out, especially from cold starts. Finally broke down and bought a new starter. Now I only use it for starting when the engine is hot. If you're properly jetted and the valves are in spec, it will fire up on the second or third kick.
  • pYura
Posted July 14, 2007 - 11:35 PM
I have heared that it is hard to start the WRs after falling. What is your experience?
  • pYura
Posted July 16, 2007 - 03:41 AM
  • Anthony CRF450
Posted July 16, 2007 - 02:59 PM
my 05 starter died after 1500kms , i had it repaired at an auto electrician.
i try not to over-use it now.
  • Quick Draw
Posted July 17, 2007 - 10:45 AM
Lucky bastards with e-start....It's a bitch to kick my 400 when it's cold....
  • paulkimson
Posted July 18, 2007 - 08:05 AM
Thank you for your kind comments. I found that battery charging was not enough to start the engine. Due to not ride it frequently, not enough time for full charging the battery, I guess.
Thank you!!
  • paulkimson
Posted July 18, 2007 - 08:07 AM
After falling: it takes a bit longer time to start it again than normal start.
