how to tell what year kx 250 is ?
18 replies to this topic
  • Pwmotorsports
Posted July 12, 2007 - 12:25 PM
Hi,
Need to try and figure out what year the kx 250 i just bought is any easy way to do this ? been told its a 95 but have also been told that the blue forks are a sign its a 91-93? pictures to follow tommorow but any pointers would be great
  • radonc73
Posted July 12, 2007 - 01:03 PM
On the front of the frame behind the forks there should be the VIN plate. That should tell you the year. I think it is also in the series of VIN #s.
  • ebeck
Posted July 12, 2007 - 01:21 PM
What is the VIN # on the head tube?
Got picture or link?
  • gchprime
Posted July 12, 2007 - 01:59 PM
Hi,
Send me a picture and I can guess. :thumbsup:
  • motoxracer9205
Posted July 12, 2007 - 02:41 PM
go to progressive.com and get an insurance quote on powersports and enter the vin when prompted. It will fill in vin, make, model, ect.
  • quailchaser
Posted July 12, 2007 - 08:54 PM
Get the VIN number off the the stearing head tube as others have stated.
Then Go Here and type the VIN in the Search by VIN box and click on the continue button.
kawasaki.com
  • Pwmotorsports
Posted July 13, 2007 - 04:07 AM
site doesnt recognise the number this may be because its not a US model as its in the UK ? what digit relates to the year ? 10th from left ? do you incluse the - as a digit ? kx250j-003995 eng number is kx250 je004004
  • quailchaser
Posted July 13, 2007 - 10:03 AM
You are correct. It won't recognise out of US VIN's. I missed that you were in the UK.
I'm not sure how to find the exact year based on the above style of vin number.
However, Kawasaki has a Letter and digit system in thier model to indicate the year. In the US this has nothing to do with the VIN. It is just the model.
KX250J-(1;2) = 1992;1993
KX250K-(1;2;3;4;5) = 1994;1995;1996;1997;1998
KX250L-(1;2;3;4) = 1999;2000;2001;2002
With your vin starting out as KX250J I would suspect that it is in fact either a 1992 or 1993. But, I'm not sure because there should be a number or letter in the VIN that defines the specific year. It still may be a 1995. The Kawasaki UK site does not offer a VIN search. Maybe call up a dealer in the UK and ask them.
  • Pwmotorsports
Posted July 14, 2007 - 01:07 PM
thanks ive passed this onto my local shop and they are going to get back to me im just eager to order a gasket and seal kit for it but of course no point untill i know the right year! also needs the kick start looking at if i press it down slow it kicks but a normal fast kick and it wont kick it just slams down like its not turning the motor over then there is the forks which they guy just did the seals on but must have done them wrong because they are leaking and sound like grit is grinding in them when they go up and down which doesnt sound promissing !
  • Pwmotorsports
Posted July 16, 2007 - 01:27 PM
its a 92 thanks to all that helped
  • Jeekinz
Posted January 16, 2008 - 07:17 AM
So a 1997 would read: KX250K4 XXXXXXXXXXXX
  • gixxer_76
Posted January 16, 2008 - 08:38 AM
A 1997: the 10th digit of the VIN will be a "V"
VIN's were standardized in 1981 to 17 digit VIN's for all vehicles. The first digit is the country of origin (J=Japan, 1= USA, 2 = Canada, 3 = Mexico) so all our bikes (The good bikes at least) will start with a 'J'. Count to 10 from there..... this is the year code. It goes as follows:
1980 = A
1981 = B
1982 = C
1983 = D
1984 = E
1985 = F
1986 = G
1987 = H
1988 = J
1989 = K
1990 = L
1991 = M
1992 = N
1993 = P
1994 = R
1995 = S
1996 = T
1997 = V
1998 = W
1999 = X
2000 = Y
2001 = 1
2002 = 2
2003 = 3
2004 = 4
2005 = 5
2006 = 6
2007 = 7
2008 = 8
2009 = 9
I don't know yet what they are doing for 2010 but all will be the same.
  • KDXGarage
Posted January 16, 2008 - 11:06 AM
2010 starts over at A.
http://www.kdxgarage...nformation.html
  • Jeekinz
Posted January 16, 2008 - 01:08 PM
I just checked the Kawi site, it has a 'Y' in the 10th digit which means 2000. If you want proof, I can PM the vin#. I'm curious if 2001 starts with 1 or 0
  • KDXGarage
Posted January 16, 2008 - 05:58 PM
2000 = y
2001 = 1
  • gixxer_76
Posted January 16, 2008 - 09:00 PM
Damn! I just saw, and fixed my goof. Sorry!~
  • lexik
Posted June 10, 2015 - 01:15 PM
Hi would any one know what year a kx250k 031338 is?
Thanks
  • shrubitup
Posted June 10, 2015 - 08:18 PM
Thanks
No VIN on frame?
  • KDXGarage
Posted June 11, 2015 - 01:36 AM
not in Ireland!
1998
KX250-K5 [1998] 249 mL
2-stroke, 1-cylinder, Piston Reed Valve, Liquid-cooled
5-speed, Return Shift
Color - Lime Green (7F)
VIN No. - JKAKXMKC√WA027001
F No. - KX250K-027001
E No. - KX250KE000001
PC No. - (CA) (US) 99961-0451,
(AU) (EUR) 99917-1808-01, (JP) 99911-1325-01
OM No. - (CA) (US) 99920-1866-01, (EUR) 99976-1001-01,
(AU) 99922-1891-01, (JP) 99921-1657-01
SM No. - 99924-1168-03, (JP) 99925-1129-02
Help ! It refuses to idle...no matter what.. by UglyCasanova
Dirt Bike   Make / Model Specific   Kawasaki   Kawasaki 2-Stroke
  • Hot  36 replies
YZ or KX, which should i choose? by spibar1989
Traction Issues by TheHondaRidingKxOwner
  • Hot  52 replies
01 KX 250 engine problem! Please Help! by AMP625
  • 3 replies
2006 KX250 Project by ItsJuniorJ
  • Hot  30 replies
