odo drive removal
1 reply to this topic
  • Guest_Guest_*
Posted May 03, 2000 - 07:40 AM
Hi all... I whant to know what parts i need when i remove the odo drive... spacer from a yz, or??
  • Bill
Posted May 03, 2000 - 09:24 PM
I have a 99WR and removed the odo drive. I just ordered the YZf spacer and seal and number plate. The seal and spacer bolt right up and the number plate takes a little fabrication. The YZ triple clamp has the bolt hole for the number plate centered and the WR is off set to one side.
I've posted on this subject several times. You may want to search under number plate or odometer.
Good luck and let me know if you need anything else.
Bill
86TT225, 98CR80, 99WR, WR timing, throttle stop trimmed, air box lid removed, White Bros head pipe, silencer and air filter. Odometer and headlight removed. Moose hand and mud guards.
