baja kit installation suggestions?
1 reply to this topic
  • Guest_Guest_*
Posted May 01, 2000 - 09:31 PM
I own a 00' wr400. I want to make it street legal with a baja kit, but still do a lot of dirt riding. Before I install the kit, are there any modifications and/or improvements I can do to this install or kit to make it easier for disconnecting and/or better for dirt ridin'?
Minor and Major suggestions appreciated.
  • Mike_S
Posted May 01, 2000 - 10:55 AM
When you install the battery in the air box, run the wires out the back of the air box. Do this by removing the air box,removing the back cover, take a drummel tool or drill and make a slot so the fuse holder will pass through,it should go out the back towards the fender-alitte in the middle.The back turn signal wires i drilled 1/4 hole in the small humps on each side of the fender.On the 00wr i left the stock headlight bulb in and have not had a problem its a 55/60w.Get a bike computer.For a mirror get the folding kind with the replacement perch, its one that does work.You need a rear reflector so i replaced the two screews facing backwards on the plate holder with L.plate reflective screews.
