oil change? 00' WR400
4 replies to this topic
  • Guest_Guest_*
Posted April 26, 2000 - 08:18 AM
I am changing the oil after break in period. The manuel also recommends cleaning the oil strainer going into the frame from the oil hose. I cannot get this huge nut (going into frame) that holds the strainer out. any suggestions? Do I need to replace the oil filter.
  • Guest_Guest_*
Posted April 26, 2000 - 08:48 AM
Try a bigger wrench this bolt is on
pretty tight but it will come off
Also to get the strainer out its a
bit tuff getting the hose off but it
can be done I did it and i'm not nuch
of a mechanic.You do not have to replace
the filter yet just clean it with a
tooth brush in some gas put your finger
in the hole so you dont get anything
in the inside of the filter
roost on john 00 wr400
  • monarch
Posted April 26, 2000 - 09:10 PM
your owners manual will tell you what size the bolt is and what size of socket or open end to use. I highly recomend this. there is nothing worse than stripping a nut.
  • Pyroted
Posted April 26, 2000 - 12:24 PM
Don't risk it. get the right size socket!!! It is torqued on there pretty good. Go and get a deep 24mm socket. It's well worth spending the money and time shopping :)
  • Moto-Mike
Posted April 26, 2000 - 12:39 PM
I had the same problem as you are having I'm pretty sure this is due to paint sealing. After the first removal it should be easier.
Getting the strainer out is also a pain, I found the easiest way was to remove the other end of the oil line (8mm head) so that you can easily remove the strainer without messing with the hose clamp.
