This is my MRI results from March of this year on my lower back. My back just gave out at work one day. Never have had an accident involving my back.The pain was so bad at the time they had to give me 2 shots of hydromorphone just so I could move to get into the machine.
Since then,lots of physical therapy, some vicodin, flexeril as needed.
Daily pain is about a 4, when it's bad I cant move for a week, a 10 on the pain scale.
I have stopped riding about a month ago because my back went out .again.
3 doctors I have seen so far. One wanted to do a fusion, One said change my lifestlye ( give up riding etc) put off surgery as long as possible, keep up with therapy.
I would love your expert opinion. From a patient point of view broken bones only hurt this bad for a few days and then they begin to heal, I have had a couple. And I do construction for a living.
Ok here goes
Findings:
Lumbar vertrebal alingnment is normal. Mild degenerative endplate irregularities are seen throughout the lumbosacral spine. Degenerative disc desicattion and disc space loss is also noted at L4-L5 and L5-S1.
Aside from degenerative discogenic changes, narrow signalintensity is unremarkable. The conus medullaras is positioned normally the T12-L1level, demonstrating appropriate contour and signal characteristics.
L1-L2 and L2-L3: Normal
L3 -L4: There is a moderate midline annular tear with disc protrusion, resulting in slight ventral effacement of the thecal sac.
There is no nerve root impingment,foraminal or central spinal stenosis
L4-L5 : There is a moderate left paramidline annular tear with small, broad based disc protrusion. There is no nerve root compression, significant foraminal or central spinal stenosis.
L5-S1 :a tiny midline annular tear and focal disc protrusion are also noted at this level, without lateralization, disc extrusion or nerve root impingement, again no spinal stenosis.
Well that about sums it up. I want to lead a normal pain free life. I am 37 very active, raced expert mx until about a 2 years ago. I feel like I am going to end up not being able to move If I keep this up. I am 6' 4" 200lbs
Your best advice please ?
I am at a loss because none of my doctors understand riding. They look at me like I am crazy or like what did you expect??:confused:
Thanks in advance
