80 Hour Maintenance?
9 replies to this topic
  • NorCal
Posted July 09, 2007 - 09:54 AM
My bike has 80+ hours on it since I bought it used last October. The fork seals are leaky, the rear shock is stiff, and I haven't even checked the valves!:thumbsup: (motor still runs great though...Go Yamaha!:thumbsup: )
I'm going to take my bike to a friend who happens to be a Yamaha Tech. I want to prepare a list of things to do in order for my bike to be in tip top shape for next season. What exactly should I have him do? Any reccomendations?
Posted July 09, 2007 - 10:21 AM
Clean and regrease the head bearings, swing arm, and linkage, change the oil and filter, service the air filter, check the valves (just for fun, of course), and change the coolant.
What'd I forget?
  • hondaman2239
Posted July 09, 2007 - 11:53 AM
idk, wheel bearings, break pads, carb cleaning/tuning, if you are really nervous or picky check the crank seals and bearings, piston bearing. timing chain. idk theres so many things that can go wrong :thumbsup:
  • NorCal
Posted July 09, 2007 - 12:57 PM
You must be mistaken on what type of bike I'm riding. I have a Yamaha YZ450.
  • jamiehughes
Posted July 09, 2007 - 03:29 PM
tell him norcal, you shouldn't have to even bust a seal open on the engine. you could actually put some grease on one of the wheel bearings, like he said, i just don't remember which one(front or back) that is actually greaseable.
  • Captaincautious7
Posted July 09, 2007 - 03:39 PM
Hate to bring this up after the engine debate the other day, but is a fresh top end in order? With 80hrs for sure and who knows what before you bought it, wouldn't that be the most important redo? At least a compression test?
  • bigbluerider4life
Posted July 09, 2007 - 06:38 PM
^^^ and a wiseco 13.5:1 compression piston
  • hondaman2239
Posted July 09, 2007 - 07:24 PM
sorry for the mishap
Posted July 09, 2007 - 09:03 PM
Checking the valve clearance will tell you a lot (more if you checked them early on). If they haven't moved, they're good.
A compression test is somewhat meaningless with autodecompression, but a leak down test will tell you whether the top end is good or not.
  • Ga426owner
Posted July 10, 2007 - 09:51 AM
What'd I forget?
good stuff Grayracer....here is a few more:
replace suspension fluids/nitrogen/forkseals
replace rear shockbearings
change brakefluid - replace pads if needed
Check/replace or regrease at the least front/rear wheel bearings
If you are wanting a new top end....this just was released by GYTR....it is on my "to order parts list". A 13.0:1 compression kit...yes I run racefuel already....and thank God I don't live in Ca :thumbsup:
http://www.yamaha-mo...3/0/detail.aspx
  • 5 replies
  • 10 replies
  • Hot  113 replies
  • Hot  36 replies
  • On January 15, 2017
