Matt,
The Transformx started out in 2001 as a set of 2002 CRF 450 bars with some hooks welded to it so that I could train with Motocross hand and upper body positioning. The bar has evolved into the transformx. The Transformx has a patented hub that is attached to the center of a motocross handlebar. The hub has two positions or what we call first and second gear. the bar ends have telescoping and swiveling "D" ring rods for attaching DURABANDS. Because the DURABANDS are attached to the ends of the Transformx and in the center they work for lateral pulling (like in turns or whipping your bike) as well linear pulling that a conventional machine can only do.
The first position (first gear) is designed for pull-ups, up-right rows and reverse curls. the hook that you see in the photos can be used for a dumbell or a pull up bar. DURABAND handles fit in the hook perfectly as well.
The second position (second gear) is designed for push ups (in the attack position) and seated rows. We have been testing the Transformx with the Concept2 rowing machines and DURABANDS. Greg Hammond from Concept2, Brian Hagen from DURABAND and myself are all Motocross riders and we have all found the three fitness machines with proper methods to be perfect for MX training and rehabing from injuries.
I have managed to break both wrists and right ankle. Training with the Transformx bar has been really effective and it helps keep me motivated because it is similar to riding when your training.
feel free to give me a ring anytime. I love to talk moto and training.
Don't know if i mentioned that I will be at Lorretta's with the Transformx from the 30th thru the third of Aug.
Rob Hill
907 230 3775
rhill@manandmachine.com
