Pig died on the trail....HELP!
5 replies to this topic
  • bobscoffeeshop
Posted July 06, 2007 - 03:37 PM
I was just riding along today when the BRP just decided to die. Nothing seized, or smoked, or clanked, or banged, or boiled....it just sounded like it was getting tough to get fuel to the engine, then sputtered to a stop.
Anyone have any "top of mind" ideas of what might have happened?
I was able to bump start it, then it ran for a moment, then it just didn't want to run, so I shut it down. It wouldn't idle.
Thanks.
  • calgaryfiddy
Posted July 06, 2007 - 03:43 PM
I had the same problem but on a city road... it just died coming up to an intersection when i pulled in the clutch.
I ended up having to crank up the throttle stop (idle thumbscrew) to finally get it to run but REASON i had to do that was because the linkage between the throttle valve/slide and the twist assembly loosened off.
Take the top of the carb off, and stick a screwdriver down into the valve and see if the screws are loose. Mine must have been loose and caused the initial problem because once i did finally take the carb top off one screw was completely unscrewed and bouncing around the valve.
Also check out my previous thread...
http://www.thumperta...ad.php?t=523009
Its quite thorough i think. If after checking spark and fuel to the carb then i'd bump the idle screw up.
  • martinfan30
Posted July 06, 2007 - 10:28 PM
is this an L or R ? if its an L, start thinking about a cdi!
  • Dual_Dog
Posted July 07, 2007 - 06:10 AM
Thanks.
Check the fuel tank vent hose (if it has one) to see if it's clogged or pinched off.
  • ttmojo1
Posted July 07, 2007 - 04:20 PM
I had an aftermarket vent hose with ball float internal end , it just
stopped letting air in as the tank went down and eventually caused
enuff vaccum to stop gas goin into carb. When I took the gascap off
I could hear air rushing in. Thats how I figured it out.
Tony
  • bobscoffeeshop
Posted July 07, 2007 - 09:52 PM
Thanks for the replies...
As it turns out... it looks like it was a vacuum problem with the tank cap....and a bad plug.
  • Hot  29 replies
  • Hot  60 replies
  • Hot  35 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
