STUPID problem....(XR650L)
12 replies to this topic
  • squatpuke
Posted July 06, 2007 - 06:42 AM
Ok...first off...I suck at turning wrenches...and am "usually" phobic to work on my auto or XR650L.
But I got a wild hair and decided to attempt assembly on my new RSW triple clamp and Renthals.
As I was taking off the stuff on the handlebars...I stripped a screw and am now dead in the water...my bike (woefully) in pieces and unridable.
The screw in question, is one of the small black ones that holds the left clutch,blinker assemble.
Please, Please tell me how get that stinkin' screw outta there...
Appreciate it....
  • gabriel
Posted July 06, 2007 - 07:31 AM
Appreciate it....
pal,
i feel your pain because I did the same exact thing when installing new handle bars. the reason this happens is because those screws have thread lock and i bet you stripped the "star" part of the screw. The only way you can take those out is by heating them up.
I ended up having to buy that whole piece from the honda dealer and I also replaced all the screws with hex ones from home depot.
  • martinfan30
Posted July 06, 2007 - 09:30 AM
if you can, try to cut (with a dremel) a slot across the center of the screw head. this will make a slot to use a flathead screwdriver, or better yet a impact screwdriver. you can also try to heat the head of the screw with a soldering gun to try and melt the locktite.
  • Huffa 2
Posted July 06, 2007 - 09:51 AM
Appreciate it....
I did the same thing on the clutch perch bracket.
:thumbsup: Not sure which you mean, the PERCH or the switch assembly, since you mention both pieces.
My guess is the switch ?
  • GIANTac1
Posted July 06, 2007 - 11:44 AM
Buy a easy out.........works perfect!:thumbsup:
  • brightman
Posted July 06, 2007 - 06:53 PM
drill the head off and then after it comes apart woory about the stud
  • exaresix
Posted July 06, 2007 - 09:47 PM
After reading about them so many times, I finally bought an impact screwdriver. It is an inexpensive tool that I have used at least half a dozen times. Basicly you put the Phillips head bit in it and whack the back end with a hammer. It drives the bit into a stripped head and turns it out ever so slightly. Two or three whacks has worked every time for me.
  • martinfan30
Posted July 06, 2007 - 10:25 PM
it could be the perfect tool!!
  • AzMtnThumper
Posted July 06, 2007 - 11:12 PM
SP,
I've been an equipment tech for 17 yrs so I have a lot of tools (including easy outs :thumbsup: ). Let me know if you want me to take a shot at getting that screw out. I'll be in town all weekend.
  • GIANTac1
Posted July 07, 2007 - 12:37 PM
SP,
I've been an equipment tech for 17 yrs so I have a lot of tools (including easy outs :busted: ). Let me know if you want me to take a shot at getting that screw out. I'll be in town all weekend.
Just get a easy out, the right size, and try it. Or get the impact driver and try that! Both have ALWAYS WORKED GREAT for me(AzMtnThumper:bonk: :thumbsup::cheers: ).........:thumbsup: Then you will have the tools next time you need them!
  • Bibleman
Posted July 07, 2007 - 07:01 PM
I'm surprised that the easy outs are so popular. I got a Craftsman one and the only time I needed it the easy out broke too!:thumbsup:
  • gabriel
Posted July 07, 2007 - 07:05 PM
let me tell you something, you can't drill those bolts/screws, they are made of very hard steel and will shatter your drill bit. If you are trying , i know it sounds corny, but use eye protection, as the shards from a shattered drill bit fly with some force! Don't shard yourself. :thumbsup:
  • squatpuke
Posted July 08, 2007 - 01:34 PM
Ok...I got it.
The easy-out wasn't working for me and I was afraid I was going to break it off..
I used a larger drill bit...then found a screw driver that was the same size as the drilled hole and tapped that (the screwdriver)...then twisted out the screw. Came out relatively easy.
I was happy...
My stock triple is now off and the RSW one on...seems to be ok so far.
Now I'm fighting with cables, handlebars and grips....
Thanks for all your support.
  • 3 replies
  • Hot  141 replies
  • 17 replies
Honda XR650L 2017
  • 0 reviews
  • Hot  35 replies
