YZ450F 06 boiling
28 replies to this topic
  • TG-107
Posted July 06, 2007 - 04:34 AM
Hi, i got a YZ450f, it has an athena big bore sleeve , boysen quick shot and a FMF titanium factory 4.1, gytr radiator braces and run on belray thumper oil(10w40), but after riding for about 25min moto the water in my radiotors boils, i replaced the radiotor water, after flushing the cooling system but didn't help!!! also rejeted it but it didn't help.:thumbsup:
please help!!!!
  • FLjoyride
Posted July 06, 2007 - 06:22 AM
did you add water or coolant..?
  • tnl
Posted July 06, 2007 - 07:27 AM
Are the radiator caps in good working order (pressure test) and are the overflow drain lines free of dirt or debris?
  • TG-107
Posted July 06, 2007 - 11:12 AM
Yeah did add water and tried different collants, the cap is fine cause i tried a new one aswell, did anyone try that "twotwocool" (think thats what its called, think its spelled wrong)????
yeah the lines are all clean and run freely!!!!
  • ben_suhard
Posted July 06, 2007 - 11:31 AM
Are you filling the radiator to the top? The coolant level should only be about 10mm above the radiator core when cold, otherwise when the coolant gets hot and expands, it'll overflow.
  • TG-107
Posted July 06, 2007 - 11:36 AM
yeah i know thats normal but you can hear the water boil and when you check the water level, you can't even see the water!!!
  • ben_suhard
Posted July 06, 2007 - 11:47 AM
Maybe you need a new impeller in the water pump?
  • TG-107
Posted July 06, 2007 - 11:51 AM
no already checked it, it looks new!!!
I'm stumped!!!
  • steveasba
Posted July 06, 2007 - 09:27 PM
Mine overheated until I put in engine ice. It never coughs up coolant now
  • black_n_blue_thumper
Posted July 07, 2007 - 09:45 PM
Exactly. Mine used to boil very easily, now it never boils. Engine Ice works for me. :thumbsup:
  • ben_suhard
Posted July 07, 2007 - 10:15 PM
So, is it coming out the overflow? If not, maybe it's leaking into the engine because a gasket is stuffed or the barrel or head is cracked or warped etc.? Does it blow white smoke out the exhaust?
  • TG-107
Posted July 08, 2007 - 12:17 AM
just tried that two2cool and its gone:)
thanks everyone
Posted July 08, 2007 - 07:55 PM
Isnt two2cool an oil additive. How would that keep your rads from boiling? If it makes the engine THAT much cooler, I need some.
Posted July 08, 2007 - 08:01 PM
It is, and it won't.
  • TG-107
Posted July 09, 2007 - 01:53 AM
like i said i used it and my bike doesn't boil anymore:)
  • MikeDD
Posted July 09, 2007 - 01:59 AM
:thumbsup:
  • djtroy
Posted July 09, 2007 - 10:55 AM
oil additive in the radiator?????
Posted July 09, 2007 - 11:18 AM
Okie Dokie.
Anyone who has a plausible explanation for how that works is invited to present it.
  • hondaman2239
Posted July 09, 2007 - 12:01 PM
i use engine ice too, good stuff. maybe the gaskets, or soemthing is blocking the flow in the engine block? total guess, dont go rip apart your engine unless thats a definite possibility.
  • TG-107
Posted July 10, 2007 - 12:13 AM
its an oil addative and it apperently helps transfer heat between the oil particles quicker resulting that it cools down faster.
i think
  • 3 replies
  • Hot  47 replies
  • Hot  30 replies
