RV windows, want to add some to a cargo trailer, source?
12 replies to this topic
  • Gadsen
Posted July 05, 2007 - 08:50 PM
OK, looking for a source to purchase RV windows from, I want to install 2 small RV windows on each side of my enclosed trailer. I'm after those small types you'd find near a bunk on an overhead camper or a trailer. I have 16" centers for metal studs, so I'm after one that is 16" long, about 6-8" high, rounded corners, window slides half open from left/right or right/left, has a bug screen. Not the flip up type, the slider type and smoked glass. I have looked with little success, anyone have a source?
  • jackdrinker48015
Posted July 05, 2007 - 11:45 PM
camping world
  • fl-cracker
Posted July 06, 2007 - 04:20 AM
I have a RV wrecking yard about 7 miles from home. You can wander around alone until you find something you like then they remove it for you. I bought a Haulmark with a 4' house single hung window it it. Not the way that I would have done it but it works OK. Yes it is a security problem; might do some expanded metal mesh over it, don't know yet.
  • Red_Snapper
Posted July 06, 2007 - 09:57 AM
I added some sliders and vents to a cargo trailer years ago and got the parts from these guys: http://www.redneck-t....com/2006/H.htm
The 6-8" requirement is going to make it tough.
BTW, thanks for your help on my "high ground clearance cargo" post.
  • gregghealy
Posted July 06, 2007 - 10:49 AM
http://www.motionwindows.com/
This place has a bunch.
  • Gadgetman
Posted July 06, 2007 - 02:17 PM
Try this place, http://www.waltsrvparts.com/online/ it may be a little far for you,but they have great prices on surplus parts.
  • tkrrox
Posted July 07, 2007 - 02:58 PM
once you cut it out then you have to header it and put in a sill...sounds like a pain in the rear and very hard to make look factory...clean
  • Gadsen
Posted July 07, 2007 - 05:02 PM
No, they are made for wall thickness from 2" to about 8", as for the header, I have a MIG welder, will weld in angle iron, secure it like any RV with butyl tape behind it. Trust me, I can make it look factory installed. Now I just need a source. So far, some of the links have been closer than what I have found. Anyone else???
  • Chickenhauler
Posted July 07, 2007 - 09:55 PM
These guys are suppliers to the RV manufacturer's and custom sleeper builders.
They can make anything your wallet desires.
http://www.interstat...ion-catalog.htm
  • tkrrox
Posted July 08, 2007 - 07:51 PM
aren't the studs wood? i know some are al., but i would love to see pics of that cause my wife wants a window added...and if anything like house framing you need to cut the stud further down/up than the hole for the window to install the header and sill...do you use a router or what...i'm really curious to see a retrofit detailed article w/ pics...
  • Gadsen
Posted July 08, 2007 - 08:19 PM
No, my studs are 16" OC and are a "Z" shaped. The opening for the window will be about 15 1/2" wide, height, I'm flexible, but dont want it big enough for anyone to be able to crawl through. I only want cross ventilation and to be able to look outside if I hear something etc. My trailer is a enclosed cargo type, no wooden studs. I have a roof vent with a fan, but on hot days with no shore power (to run the AC) I need cross ventilation or it gets too warm and muggy inside. I can leave the door open, its an RV type door, but has no screen. As for cutting the skin on the outside, I have a Roto-Zip and I can get the metal spiral saw bits, same goes for the wood inside. I will cut the opening, then add horizontal supports above and below the opening. I will weld them through the hole I just cut. Stuff it with a wet towel to catch and extinquish any sparks from setting the inside wooden walls on fire.
  • DEA
Posted July 09, 2007 - 01:36 PM
I got a used one from a camper trailer sales.Haven't installed it yet though.
  • altered
Posted July 12, 2007 - 08:52 AM
http://www.hehr-inte...ow Products.htm
These are the windows Haulmark used when I ordered my trailer.
