Pull engine or 'in frame' rebuild?
2 replies to this topic
  • Ebs
Posted July 05, 2007 - 05:52 PM
I'm replacing the whole top end (cylinder, piston, head) and I would like to inspect the bottom end as well to make sure it's healthy. Should I just go ahead and pull the engine and get to splitting the cases or can I leave it in the frame? Will pulling the side covers off give me a good look at the lower end in addition to checking the rod play when I replace the piston/cylinder?
The previous owner said he had the bottom end rebuilt with low hours, but the bike ate a valve so I just want to be sure all is well before putting the top end back together.
  • Mutu
Posted July 06, 2007 - 04:26 AM
You don't have to pull the motor to check that, but if you do, it is only a little bit more work like a few oil lines and swing arm.
  • TG-107
Posted July 06, 2007 - 04:37 AM
easiest will be just to pull the engine then uou got much more space!!!
  • Hot  50 replies
  • Hot  28 replies
  • Hot  36 replies
