suspension
16 replies to this topic
  • Darren_Santilli
Posted April 03, 2000 - 12:56 PM
I've just bought a new '00 WR400 and was dissapointed to find that the standard spring that comes with the bike only takes riders up to 154 pounds in weight.
As I'm 190 pounds, I'll have to go for the stiff spring upgrade, but there is three different stiff springs to choose from. Does anybody know which ine I should go for?
Other than that,.......the bike is fantastic.
Darren
England
  • JamesD
Posted April 03, 2000 - 02:07 PM
SAY WHAT???? Whatever happend to just bumping up the spring preload! If you need to replace yours so will I! I weigh 200lbs!
  • Darren_Santilli
Posted April 03, 2000 - 02:31 PM
It says so in the manual....
To get to the correct sag, you have to wind the spring up past its recommended minimum length.
(For persons of our weight)
check out the manual... page 7-18 (section 7, page 18)
  • Paul_Mooney
Posted April 03, 2000 - 03:26 PM
I agree with Darren. I weight 200, my spring is tightened beyond minimum length. Is at 9 1/8" now there is no static sag....so we're in same boat,,but budget is shot so I will live with it this season. Am just goin to back it off til the static sag comes back and leave it.
  • Guest_Guest_*
Posted April 03, 2000 - 03:36 PM
You folks need a heavier spring for your shock. I have a '99 WR. I weigh about 240 with gear or about 110kg. I left the fork stock - I believe 0.46. I went to a 5.6 RaceTech spring for the shock. Now the front and rear are much better balanced and it works well for me.
Eric in WA
  • Heywood
Posted April 03, 2000 - 03:49 PM
I am about 260 lbs and just ordered a 5.6 shock spring from Yamaha.
Race Tech recommended a 5.8, but I thought I would try the 5.6 first. If I make the jump to 5.8, I would probably need to increase the fork springs to keep things balanced and might need to re-valve too.
Limited funds, so I thought I'd give Eric in WA's setup a try. I'll post how it works out.
Heywood
  • MotoGreg
Posted April 03, 2000 - 04:11 PM
I'm about 230 without gear. I have .47 in the forks and .58 (with 13mm preload) for the shock. If I wasn't going to be doing any MX track then I probably would have went with a .56 for the shock.
'99 WR400
'92 GSXR 7/11
Visit my photo album AT YOUR OWN RISK!! My photo album
Anyone here a sportbike fan also? Then visit us here at www.insanespeed.com
  • Heywood
Posted April 03, 2000 - 04:18 PM
Hey MotoGreg:
Did you do any re-valve with that 5.8 or can you get a decent set up with the stock clickers?
Is it balanced pretty good with the 0.47/5.8
Thanks for the info.
Heywood
  • paul913
Posted April 03, 2000 - 05:11 PM
Hey Darren,
Before you drop a ton of money on the springs, you might try talking to Neal at A-Loop. He still personally does three or four of the Pro Enduro guys' suspension work - Randy Hawkins & Steve Hatch.
He made limited modifications to my (XR) set up, the bike worked better at about a third the cost. (He drilled the valves and switched oil) Later that season, when my check book could cover it, I went in for the springs and valves. It's well worth the whole enchilada. My WR cost about $550 for RaceTech valves and springs.
You will need to get fairly specific with your riding type - enduro vs MX. There isn't any switch or clicker that will help us big guys with both.
Jake
240# without gear, and I carry a lot!
  • Bruce_in_Phoenix
Posted April 03, 2000 - 08:12 PM
You can change the spring yourself in an hour or so. Its a piece of cake if you have a couple sockets and a pair of vice grips(he he oops those are for the Hondas :D)I am 195 in riding form and the stock springs on my 99 are fine of course the race tech internals I installed make a difference too. By the way its important that the octane rating of your fork oil be a minimum of 187 otherwise when the pressure builds as the fork compresses you could get preignition and cause a harsh ride to occur. :)
  • MotoGreg
Posted April 03, 2000 - 09:26 PM
Bruce, ya I thought I heard pinging from the forks, must be the low octane fork oil :)
Heywood, ya they revalved everything to yz style. I don't know exactly, all I know is that it doesn't bottom anymore on hard landings and it really launches off jumps different.
'99 WR400
'92 GSXR 7/11
  • Darren_Santilli
Posted April 03, 2000 - 10:47 PM
Thanks guys...
At least I know now that I read the manual correctly...
Bruce... as far as the octane rating in the forks is concerned, if you carry a fettling stick with you and poke the forks at the given time you should be ok. BUT dont forget to get the angle of the dangle spot on or you will get up on the ginky fours and swine dive with the hookle splines. :)
Thanks again..
Darren
Buckinghamshire
England
[This message has been edited by Darren Santilli (edited 04-04-2000).]
  • Jerry
Posted April 05, 2000 - 10:22 AM
I weigh 200lb and have left the stock springs in.
O.K they're wound up to the maximum recommended, but they work fine
Hope this helps you
Jerry
CN
  • Guest_Guest_*
Posted April 05, 2000 - 12:14 PM
You all need to go on diets you fat ass bastards :)
  • JamesD
Posted April 05, 2000 - 03:23 PM
I'm 6'4" tall!!! Just how much weight can I lose? Oh, and I'm right in the ideal weight range for my height thank you very much! :)
  • Heywood
Posted April 05, 2000 - 03:32 PM
Fluke, I am afraid your right, but being the lazy fat ass bastard that I am, its easier to buy suspension parts than actually loose weight.
  • Guest_Guest_*
Posted April 09, 2000 - 12:23 PM
Just stop eating.
Then you wont be fat.
Doh !
