RINGS
1 reply to this topic
  • Howard_Robbins
Posted April 08, 2000 - 03:38 PM
I WAS WONDERING IF ANY OF YOU HAD ANY
TELL TALE SIGNS THAT YOU NEEDED TO CHANGE
YOUR RINGS. PLEASE SHARE ANY INFO. :)
  • ButtonFly
Posted April 08, 2000 - 04:09 PM
Hard starting (will bump start but not kick start), bad idle, low power, low compression. Run a compression test and use your numbers as a baseline. Not sure what is considered low... A leakdown test is the best way to test.
