results on my acc. adjustments......
2 replies to this topic
  • fred
Posted October 22, 2000 - 02:58 AM
this is what I did
If I leave the fork in close and I ride the way I nomaly do, that is tight woods lots of turns the trottle full on full off the hole time I foul plugs. But the bike runs well.
Now I open the fork so the acc starts a little later, and I ride the same. the bike does not have the quick response but It dose not foul the plug..
But I did have to adjust the pilot screw to gain some performance....
  • sam
Posted October 23, 2000 - 04:59 AM
Hmmmmmm you've been at those mushrooms again haven't you!!! :)
  • James_Dean
Posted October 23, 2000 - 07:37 AM
You are right on target. The pump can squirt too much fuel at low speeds unless there is adequate delay ("starts a little later"). 1/8 to 1/4 throttle is where it should start to flow. Tight woods is a good example of a situation where the low speeds can't be avoided. Readjusting the pilot screw can fill in to a lesser extent.
In more wide open conditions the pump can be set to flow earlier giving a quicker response without a problem.
