Info on AP mod
4 replies to this topic
  • The Italian Stallion
Posted July 03, 2007 - 06:34 PM
Is there a page with step by step instruction on this mod that Ican print out? thanks guys.
Posted July 03, 2007 - 07:06 PM
Go to the Common Threads sticky and scroll down to Fuel System. The second link under Baron von Beard's AP mod leads to a PDF file that you should be able to download and print.
  • Racer24
Posted July 03, 2007 - 07:17 PM
http://www.squadpage...w-To AP Mod.pdf
"The AP works off of the linkage spring pressure and all that happens is the linkage moves and allows the spring pressure to push the AP rod which pushes the diaphram, which pushes the fuel out of the AP cover into the motor. The problem is that the spring pressure isn't enough to instantly overcome the pressure that the fuel creates while trying to be shoved through a small orifice. By linking the AP link lever to the AP timing screw tab, it forces the rod to push the fuel instead of relying on the linkage spring pressure." --Redbeard's reason for the Ap mod
  • twenty34
Posted July 03, 2007 - 08:07 PM
Suggestion: Pay and have ZipTy racing do it. Much less hassle and they do more than just the AP wiring...Do a search if you have any doubts.
  • Ga426owner
Posted July 04, 2007 - 05:13 AM
agreed...I 2nd that:thumbsup:
  • Hot  47 replies
  • Hot  30 replies
  • Hot  38 replies
