If I was to put a stock yz silencer on my wr would I have to change the jetting??????
3 replies to this topic
  • fred
Posted October 20, 2000 - 02:28 AM
I would like to change the silencer to shave some weight...
I quess about 3 pounds...
take off my light, odom.. just when racing to save some pounds and not get my light broken...
  • CAB
Posted October 20, 2000 - 07:11 AM
If you take off the spark arrestor and install a moto-X silencer, there will be less back pressure and your bike will run quicker. It may also run a little warmer. Consequently, you should probably plan to richen your jetting a bit.
  • Tommy
Posted October 20, 2000 - 01:39 PM
YES-I HIGHLY RECOMMEND A JETTING CHANGE. I HAVE A 1999 WR400 W/ A YZ EXHAUST. I MADE THE FOLLOWING CHANGES: 48 PILOT AND 178 MAIL.
KEEP THE NEEDLE AND CLIP IN THE STOCK POSITION. YOU WILL BE IMPRESSED WITH THE CHANGES. I LIVE IN SOUTHERN CALIF.
  • James_Dean
Posted October 20, 2000 - 02:10 PM
Fred,
You don't HAVE to change it. It can be set up better though, if you want to run both ways on the same jetting. Make your jetting a little rich for the racing setup and it should be able to switch back and forth with good performance.
James
(Did I mention there is a YZ silencer on my WR? :) )
