how to make a wr426 longer gearing
3 replies to this topic
  • mattmx426
Posted July 03, 2007 - 03:28 AM
i have a wr426 an it could do with a nother gear or is it because i have a big sprockit on the rear at the moment its runing on a talon motocross sprockit could it be this? if yes what sprokit an front sprockit would be the best to go for longer gearing
thanks matt
  • byggd
Posted July 03, 2007 - 03:57 AM
How many tooth sprockets are you running now? The 426 came stock with a 14/50 combo.
  • 04WR450man
Posted July 03, 2007 - 08:05 AM
I fitted a 15/50 to my 426, it stopped it screaming its bollox off on the road between trails..............made the gearing a bit high in the really tight stuff but I found it worth it.
You can always fit a 14T to the front for doing mx tracks/ enduro's etc as it only takes 15mins to change
  • mattmx426
Posted July 03, 2007 - 11:11 AM
ok thanks for your help i will give it a try
thanks matt
