Oil from Ignition Cover & Breather
1 reply to this topic
  • Guest_Guest_*
Posted October 16, 2000 - 05:45 PM
I've read in the forum that the WR has a "wet" ignition. This weekend the timing plug was a little loose and quite a bit of oil seemed to be coming out. Also when I stopped riding oil dripped out of the breather for a few minutes. I've seen oil come in the past, but not this much. I tighten the plug and checked the oil level. Everything seemed to be ok and the bike was running fine.
Has anyone experienced this??
Thanks
MH
  • Taffy
Posted October 16, 2000 - 10:20 PM
st louis
they all chuff out of that breather. this is a very tiny engine with a big piston inside going like hell.
the crankcase has to be able to breath & there is a special system for letting thousands of litres of air out of your engine & not oil.
unfortunately a little oil does get past the sentries, the barbed wire, the rottweilers, the ditch, the wall & the search lights!!!!!
if anything is loose it'll seap oil.
Taffy
