Need Help, Metal Filings In Oil Xr650r
9 replies to this topic
  • MIxr650r
Posted July 02, 2007 - 09:01 PM
Long story, short version. Bought a 2002 XR650R (bone stock) from a police auction. The bike's V.I.N. and engine number is ground off and the police auctioned it because there is no way to find the owner. This was obviously stolen from a dealership. It is brand new, still has the paint check marks on all of the main bolts and no grim at all anywhere on the bike. Just some minor lay down damage to the plastics from who ever stole it. I'm pretty sure it's a 2002 by the federal emmissions sticker on the topside rear fender, but not 100% sure.
Anyways, I just changed the oil and found some metal filings in the pan. There is also a blue piece of plastic that is the same shape and size of the other filings. I'm not sure if this could be trouble or just from the break in. I have a 2003 XR650R that I bought new and didnt have anything in the oil, but I wasnt looking either. Just wondered what you guys thought. Maybe the notorious 2002 bushing thing needs to be replaced?
Thanks in advance for your help.
I'm going to try and post a pic of the filings.
sorry cant figure out how to do it, send me a message and i can send u the pic.
thanks again
  • porterdog
Posted July 03, 2007 - 05:56 AM
Could be two different things:
1. Normal break-in (relatively fine, steel and aluminum colored)
2. poor rod clearances lunching your bearings. (brass/bronze colored)
Honestly, either way you should run it for a bit to see what goes on; change the oil/filter xtra often for a bit and make sure you clean the downtube screen as well.
Luck!
  • Billahjack
Posted July 03, 2007 - 06:10 AM
Get a magnetic drainplug too.
  • MIxr650r
Posted July 04, 2007 - 05:17 AM
Thanks very much!!
  • doublediesel
Posted July 04, 2007 - 08:10 AM
Worn connecting rod end...
  • Butta
Posted July 04, 2007 - 04:06 PM
We obviously don't know for sure how much the bike was used, but that would be a slim-none chance for it, with the reliability these bikes have enjoyed.....start simple......
  • Moredesert
Posted July 06, 2007 - 12:09 PM
I've seem metal flakes in my oil on a DRZ400 that I desert raced. I had used the clutch to the point it started to slip from the heat. In time I had to replace the clutch and basket because it would chatter even with new plates. If the BRP was stollen and ridden like a two stroke I can see where you would have metal shavings from the clutch in the oil. On the other hand my BRP has 18k miles on the clutch and I finally replaced it. The clutch basket was so worm out I had to replace the whole thing, but it didn't slip. I just felt it was time to replace it before it goes out when I'm 300 miles south of the border. For the most part the 650R is bullet proof and can take a good licking. I would just keep good oil in it and change it all the time.
  • doublediesel
Posted July 06, 2007 - 04:21 PM
I was sharing my experience......
  • doublediesel
Posted July 06, 2007 - 04:24 PM
Thought I'd share my experience.. and it's more common than one would think.:thumbsup:
  • MIxr650r
Posted July 09, 2007 - 05:51 PM
thanks again guys. going to ride it and keep an eye on the oil. i'll change it regularly. we dont ride em' too hard, just trail riding on 2 tracks and stuff.
