2000 WR cracked carb slide
4 replies to this topic
  • Michael
Posted October 12, 2000 - 11:20 PM
Has anyone cracked a carb slide on a 2000 WR or has the new carby fixed this problem?
Its a wonder someone doesn't make a stronger after market slide and a stronger 4th gear.
Has anyone had gearbox problems on the 2000 WR. It sounds like the YZ426 are having a few go.
  • Michael
Posted October 13, 2000 - 11:19 PM
I guess by no response there all still going ok!!
  • Henry
Posted October 14, 2000 - 06:37 AM
Hey Michael, I got this throttle slide problem with my 98 WR400
I have already change this the second time.
It is so expensive to replace one.
Wondering if I should get the WR250F.
'98 WR400F, YZ timed, main:180, pilot:48, DVR needle 4th clip from top,
snorkel removed, YZ tank/seat combo, YZ front no.plate/rear fender,
DSP Ti exhaust system, Brembo front brake,steel braided hose, EZ clutch adjust perch,
Stroker billet rear brake reservoir
  • Scott
Posted October 16, 2000 - 06:50 AM
Hey Henry, where are you buying your carb slide and for how much?
I just bought one at sudco (sudco.com) for 81.00.... My local dealer wanted 116.00 so I hope 81.00 is a good price.
As you know, there are several names for this piece. Funny though, I have only heard it called a carb slide on this forum.
99WR,WR timing,throttle stop removed,Uni filter,E-Series pipe,carbon air box,Pro Tapers,lights removed,YZ tank,13 tooth sprocket
  • Henry
Posted October 16, 2000 - 04:46 PM
Hi Scott, I think you got a good deal with sudco.
I got mine for S$150-160 depending on the Janpanese yen.
The actual name for this if I have not get it wrong should be " throttle slide plate".
Seem like no one has a solution for this yet, even a 2000WR got this shitty problem.
[This message has been edited by Henry (edited 10-16-2000).]
