Help! Bike has no low end power
1 reply to this topic
  • Rich_Clarke
Posted October 14, 2000 - 11:29 AM
Had my carb checked out and cleaned recently
and ever since then it seems to be lacking
low end power-0-1/4 throttle
what are some things i should look for
any help greatly appreciated.
Thanks, RFC
  • James_Dean
Posted October 14, 2000 - 03:15 PM
-Air leaks are the first thing.
-Check where your pilot screw is set at. (on the bottom of the float bowl) How many turns out? Write it down. Try turning it 1/4 turn out to see if it improves, then 1/4 turn in and compare. It may have been adjusted from where it was at originally. Out is richer - more fuel.
-Make sure the accelerator pump is working and that it is activating at near 1/8-1/4 throttle.
-Make sure no dirt got in anywhere during the cleaning. There are air jets on the intake side of the carb to check.
-Was the needle clip moved?
