ATK bike shoe
14 replies to this topic
  • desertman
Posted October 02, 2000 - 07:14 PM
Do you or anyone you know use these? Does it really hold a dirt bike by itself (without tiedowns)? Thanks.
  • Guest_Guest_*
Posted October 03, 2000 - 06:18 AM
Been using one now for about a year. Works great! It will hold the bike without any tie downs and makes loading/unloading simple.For extra insurance (because I'm the anal type) I run a nylon strap with fast clip around the front wheel and shoe; if all else fails the bike won't fall off the back of the truck. Ps; everybody that sees it in use lovesw it and wants one.
  • BruceWA
Posted October 04, 2000 - 11:06 AM
Been using them for the last 10 years. Will NEVER go back to tie downs. However, the first one I bought was aluminum. It bent when the trailer wheel went over a curb. The weight of the bike was enough to allow enough momentum in the swing to bend it over. They replaced it with a steel one. It is strong. Have two of them Still have an old aluminum one, but I always make sure my buddies get to use it. hehe.
  • Guest_Guest_*
Posted October 04, 2000 - 02:40 PM
I ride with one guy who used them for a year and then quit..... because so many people went driving by waving at him to let him know something was wrong because they thought the tiedowns had come off... so he quit using them.... the bikes ride higher and wiggle around more, and people freak. He got tired of stopping to look at what was wrong.... and nothing was.
  • Guest_Guest_*
Posted October 04, 2000 - 02:42 PM
The only problem with using one and not tying it down too is when the trailor rocks back and forth and geos over bumps the bike also sways back and forth. After this goes on for several miles your looking at replacing your front wheel bearing on a regular basis.
Darin from Missouri - 1999 WR 400F
  • Scott_F
Posted October 05, 2000 - 07:30 AM
I don't know about the wheel bearings, but it has to place a load on the spokes. The solution to prevent the rocking is to lightly attach tiedowns in the usual way. This may seem redundant, but I do it that way.
BTW, I have an extra bike shoe for sale.
  • Gary_Kessler
Posted October 05, 2000 - 10:16 AM
I just ordered one.
It's gotta make putting the bike away easy and getting ready to ride quick! I'll probably use a tiedown on my rear wheel so the bike doesn't flop around. That's much simpler that all the strap nonsense I do now. . .
'00 WR, YZ modified and dodgin' Roadrunners and P-dogs. .all with no damper!
  • GPS Dual Sport
Posted October 05, 2000 - 10:37 AM
Major Warning! If your front tire goes flat it will walk right out of the shoe. A friend of mine had this happen in his enclosed trailer. He didn't find out until he opened the back door of the trailer and found the bike on the floor and a completely trashed interior.
  • BruceWA
Posted October 05, 2000 - 03:33 PM
Since I have hauled my bike on several occassions with a flat front, I'd guess that he didn't have the bike all the way forward. On those times I've done this the bike never moved at all.
  • Dan
Posted October 10, 2000 - 03:17 PM
I am now using 4 of these. Works great in an enclosed trailer if you are careful to make them tight but not too tight. They can probably put huge stress on a wheel. Mine are mounted to a piece of 3/4" plywood with carpet on the bottom. Plywood is just tied down to existing floor hooks.
  • Ron_in_SoCal
Posted October 10, 2000 - 04:04 PM
Here is a homemade rack for the back of my pickup truck. It stops the front rail of the bed from colapsing against the cab and holds three bikes rock solid. I back the third bike in, so the middle tire slot is wider.
This is the third truck I've used this in. It's made of 2" square tube, and with a miter box & welding machine, it's cheap and easy to make. Note the lugs on top for the tie-downs.
Works for me!
  • Guest_Guest_*
Posted October 10, 2000 - 04:51 PM
Pretty Slick :)
  • Scott_F
Posted October 11, 2000 - 07:19 PM
Your setup looks familiar. Did we meet at Perris one day?
  • 426_Monster
Posted October 11, 2000 - 10:23 PM
What does this thing look like, first time I hear of it 's excistanse!!!!!!!
  • Vincent
Posted October 12, 2000 - 04:30 AM
Ron,
Dont show that puppy to the whole world, market it!!! I'll bet you could sell them like hot cakes!! :)
