2005 wr450 valve adjustment
1 reply to this topic
  • txwr450
Posted June 30, 2007 - 12:42 PM
trying to check my valve clearance and I have no clearance with the stoke settings. Cams are aligned correct and tdc ounch mark lines up. Is it possible that I'll have to go down on pad size?
  • clark4131
Posted June 30, 2007 - 09:04 PM
How many miles are on the bike? Are you absolutey sure you're at TDC? If so, then yes, you need to change out your shims...SC
