Counter sprocket/ nut?
3 replies to this topic
  • 2012 450 xc-w
Posted June 30, 2007 - 05:22 AM
having difficulty breaking the nut loose with just the brake. Anyone see any problem with using an impact to loosen the nut?
  • 642MX
Posted June 30, 2007 - 06:01 AM
An impact will work fine. Thats what I always use. :thumbsup:
  • warrior86
Posted June 30, 2007 - 06:44 AM
i have always found that a long1/2 inch ratchet and hittin it with a mallet was always a good way to break things loose without rippin my hand up.:thumbsup:
Posted June 30, 2007 - 07:35 AM
An impact is fine, BUT, don't put the transmission in gear when you use it. Just hold the wheel if you still have the chain on, or grab the sprocket with a rag and a big pair of pliers.
Using the engine to hold the sprocket puts a lot of unnecessary abuse on the trans and primary gears, and they get enough of that from you already. :thumbsup:
  • Hot  47 replies
  • 10 replies
  • 5 replies
  • Hot  38 replies
