TDC - Ignition question
1 reply to this topic
  • Hick
Posted October 09, 2000 - 06:46 AM
How does the ignition know where TDC is? Does it just fire at x degrees before TDC every revolution (i.e. fire on the exhaust stroke AND compression stroke)?
I realize it knows the crank position but how can it know where the cams are?
I’m sure there is a simple answer and I’m curious as to what it is…
  • Taffy
Posted October 09, 2000 - 01:39 PM
hick the engine has a wasted spark-it fires EVERY TIME the engine goes around.
the only way anybody does it any different is if they put the ignition on the camshaft. this though, is a bad move due to all the lash of the camdrive.
the only thing that wears out quicker is the plug!
Taffy
