Stator replacement for a light kit?
6 replies to this topic
  • hondacrf150f1
Posted June 29, 2007 - 06:10 AM
i wanta put a baja designes light kit on my 2007 XR650R but ive been told the stock stator cant handle that. Im thinking order a new 1 from ricky stator? $150 then another $500 for the light kit! Any cheeper options? to get a plate here in CT i need everything, signals, high/low beam, horn, tail light.
anybody have pics of there XR's with the electrosport or baja designes kit on it?
thanx,
  • Coolidge
Posted June 29, 2007 - 06:45 AM
Here is my 97 XR600R w/BD kit. I have stock stator, and everything works fine. If I were to upgrade lights, I would add the Ricky Stator assy (I will eventually get one anyway
  • black in RI
Posted June 29, 2007 - 08:20 AM
my 650 r works fine with a BD ligt kit and is street legal and passed inspection. i even ride it at night... however someone told me in PA that my brake light was barely visible when engaged on a group ride last week. I'll just rewind the stator
  • cleonard
Posted June 29, 2007 - 10:56 AM
You should be ok with the stock stator. You just have to use a standard wattage headlight bulb. The stock stator should be good for about 70 or so watts. If you want more light then you need a high output stator.
  • hondacrf150f1
Posted June 29, 2007 - 06:20 PM
well maby ill try the stock stator to start. Ill proble do LED brake light and turn signals to so that may help
  • jwcbf
Posted July 07, 2007 - 10:19 PM
Late reply,
I put a BD QR kit on my 650R a little while back. Had many issue with the lighting/charging. Did some research here and like you was hesitant to spend the extra $... put the ricky stator on and it now works like a champ.
Good luck
  • BT4Stroke
Posted July 08, 2007 - 07:41 AM
Stock stator has an 80 watt out put, RS stator has either 2-100watt leads or they can be tied together for 1-200watt out put lead. BD will rewrapp the stock stator for you either with 2-125 watt leads or a single 200+watt lead which is used in the our race bikes to power up the HID BD lights. There are several post regarding wrapping the stator yourself.
  • 22 replies
  • Hot  35 replies
Honda XR650L 2017
  • 0 reviews
  • 4 replies
  • Hot  29 replies
