Tire Tech
4 replies to this topic
  • Bryan Bosch
Posted October 04, 2000 - 10:56 AM
Ok, stock rear is 100/110-18. What are the costs and benefits of:
Wider/lower profile?
Wider/taller profile?
Narrower/lower profile?
Narrower/taller profile?
  • Eric_in_WA
Posted October 04, 2000 - 03:32 PM
A few things to consider:
Changing the height of the tire affects gearing and steering geometry. A 1" diametral change for one tire equates to about a 0.5 degree change in steering angle if everything else is left the same.
Narrower tires tend to wear more quickly.
Eric in WA
  • Darren_Santilli
Posted October 04, 2000 - 03:37 PM
the uk bikes come with 130/90 18's on...is this better or worse do you think?
  • Bryan Bosch
Posted October 04, 2000 - 04:31 PM
So, a taller tire steepens the rake of the forks, hence the bike will turn more quickly?
  • Hick
Posted October 05, 2000 - 09:23 PM
I never thought about that. I guess it is the same as raising the fork tubes in clamps.
I’ve always run a 120/90-19 on my YZ, this works well off-road but I’ve heard that guys use them on tracks as well.
At any rate going from a 110/100 to a 120/100 would result in .8 inch taller tire and the same amount wider (due to 100% aspect ratio). Taller sidewalls will soak up bumps better, wider tread should give better traction.
I could be wrong about the .8 inch but I don’t think so, if not that amounts to a bit more gearing than one rear tooth (50 to a 49).
