07 Wr450 throttle stop length
20 replies to this topic
  • ducatiwv
Posted June 26, 2007 - 08:52 PM
I must be missing it, but i ve searched and searched this forum and can't find the correct length to cut my WR450 throttle stop screw too....I m picking up the Wr on sat. and have ordered the TT AIS kit and JD jet kit which doesnt include the throttle stop screw, but i cant find anything on this forum that tells me the correct length to cut the present screw....I need the overall length of the cut screw if possible....thanks, Larry
  • Matt James
Posted June 26, 2007 - 10:31 PM
I cut mine off at where the threads meet the straight unthreaded portion.
This makes it shorter than needed and the linkage hard stops against the top cover above the slide. There are myths that you can get stuck wide open, but if you look at how the linkage works its impossible to stick wide open unless the top cap comes off. I also did this to my 05 WR250 and last time I looked at the bottom of the slide cover it has some shiney marks where the linkage has hit, but not real wear.
If you have to cut it exact, just back it out till your slide is all the way up and see how far it is out and cut that much off.
  • ccoates445
Posted June 26, 2007 - 10:43 PM
just get the yz screw and that will git-r-done
  • ducatiwv
Posted June 27, 2007 - 05:35 AM
Thanks , i appreciate that....I know my dealer wont have the Yz screw in stock and would like to do all the mods while i m working on the carb.....:thumbsup:
  • resinlips
Posted June 27, 2007 - 05:57 AM
From the flat bottom or back of the screw it's .072 inch or 18.3 mm or a C hair under 3/4 inch
  • markturbo
Posted June 27, 2007 - 06:19 AM
  • ducatiwv
Posted June 27, 2007 - 06:45 AM
Thanks Guys.......thats why i like this place....NO BS ....appreciate it.......
  • RD73
Posted June 27, 2007 - 12:27 PM
You may want to check out the kit from Yamaha, it includes the shorter throttle stop. http://www.yamaha-mo...0/0/detail.aspx
  • clark4131
Posted June 27, 2007 - 02:00 PM
If you've adjusted your needle enough to the rich side, i.e. more grooves, it can pop out of the needle jet and stick open. I just simulated it on a buddies '06 that I just set up 4 days ago. Rookies :thumbsup:...SC
  • ccoates445
Posted June 27, 2007 - 08:31 PM
I'm sorry but I have to say it. Cutting down your WR screw is just plain mickey mouse. There, I feel better. As well, you have a buttload of work to do installing all the new goodies. Don't waste your efforts on a shortcut. I know WV doesn't have a Yamaha dealer on every streetcorner like we do here in AZ, but be patient and have them get the right part so you only have to do it once. You'll be glad you did.
Fight-On!
  • ducatiwv
Posted June 27, 2007 - 09:23 PM
Fight-On!
Im going to be pulling the carb anyway to install the Jd jet kit, doing the TT ais mod....Plus I ve been working on bikes for about 30yrs, and also a dentist, so i m supposed to be good with my hands:lol: .....I really dont see any problem with this, its just a shorter screw, thats the only difference...
  • ccoates445
Posted June 27, 2007 - 09:37 PM
you would'nt use JB-Weld in a filling..............or maybe? jk. I just happen to be one to use the right part every time if at all humanly possible. I am extremely anal about that stuff. If I were stuck, I'd make it work 'till I could get the right part. But thats my problem, not yours. I only suggest that as a way to go that will bring more consistant success. I'm sure it will work fine. Cheers
  • ccoates445
Posted June 27, 2007 - 09:46 PM
by the way I just finished doing mine and my son's bikes with jd kits and the zip-ty mixture screws. i also put the scotts stabilizer on my bike and raised the bars 25mm. wow! what a difference.
  • Dube2
Posted June 28, 2007 - 12:02 PM
just get the AIS kit and be dun-wit-it. I cut mine when I was a rookie, hit the throttle a little hard on the driveway just to see if it sticks and it did!. :thumbsup: those little japnese guys kno-wut-they-doin. sometimes i wish i had those little hands for working on my WR. it's in the breed......
Love my 05 WR and looking to get the 07 soon for a spare...... you know, living in So Cal, my buddies YZ sits because of the red sticker issue. So I need to buy another WR just so we could ride all year round.:thumbsup:
  • RD73
Posted June 28, 2007 - 12:49 PM
also a dentist
Dentist in Gilbert, WV? Is your office there?
Just curious, I'm from Lenore originally. I noticed the same name (ducatiwv) on the R1-Forum as well. Thought I would say hello.
  • ducatiwv
Posted June 29, 2007 - 08:31 AM
Thats me on the R1 forum also.....:thumbsup: ... I ve been in Gilbert for about 15yrs and my office is there also.....Do you visit home any? The Hafield and McCoy trails keep us busy.....
  • ducatiwv
Posted June 29, 2007 - 08:32 AM
SWEET!!!......I ve got the Jd kit on its way and i ll have to do the zip ty mixture screw next...I cant wait to get the bike uncorked....:thumbsup:
  • RD73
Posted June 30, 2007 - 03:00 AM
I'll be visiting next week. Either on the R1 or I'll bring the YZ. Not sure which yet.
  • JSanfilippo
Posted June 30, 2007 - 11:45 PM
Cutting the stop to 23 mm isn't that big a deal. Measure twice, cut once, and polish off the burrs. Works the same and doesn't cost $20...I promise
  • RedBull420
Posted March 26, 2008 - 04:53 PM
QUESTION.....
So I ordered the YZ screw (right side) and when i pulled out my stock screw (left side) i noticed how much short is was than the YZ screw. I measured both and neither are coming up as they should. My stock one almost looks like it's been ground down, do they wear down when in the carb? Any ideas??? I guess i can just ground down the new on i got a C hair. Just wondering whats up with the stock one.
EDIT: I see i ordered the wrong part # 5NL-14591-00 vs. 5JG-14592-00
