petcock problems?
2 replies to this topic
  • Stumpy
Posted February 19, 2002 - 04:11 AM
Anybody had problems with the exit nipple(?) on the petcock coming out of the assembly? I was pulling off my fuel line and it came out with it. Should I be able to use a good epoxy on it or am I looking at a new unit? If I have to go new, I'll probably go with a Pingle, but I don't really want to lose my reserve. Any suggestions?
  • AZWR426
Posted February 19, 2002 - 06:43 AM
I had real good luck once with a similar situation once with JB Weld. I had a press in aluminum fitting on an aluminum casting. BUT - mine was an oil line. Perhaps calling the mfg of JB Weld would shed some light on suitability of use with fuel.
  • Joel_Gibson
Posted February 19, 2002 - 12:39 PM
Same thing happened to me on my 98 WR. When I pressed it back in I twisted it slightly and it appeared to be a reasonably good interference fit. I could feel the wrenching of the two metals and I was not able to pull it out after that (it been a year ago). It has not been an issue since. It may be that the initial press fit was not done well.
